needing a little help!
Old Apr 20, 2015 | 09:33 AM
aidenrage's Avatar
aidenrage
7th Gear
Default needing a little help!
i just acquired my 78 vet, the only thing left to be done is the turn signal lever but im having trouble finding the part name for what the lever actually screws into...any advice on where to look or the actual name of it??
Old Apr 20, 2015 | 10:09 AM
havesometo's Avatar
havesometo
I think this is the part you looking for.
http://willcoxcorvette.com/product_i...oducts_id=1428
Old Apr 22, 2015 | 02:19 PM
Bob E's Avatar
Bob E
The lever on my '78 doesn't screw in, it just pushes in----"Havesometo" has shown you the correct part it pushes into.----boB
Old Apr 30, 2015 | 10:31 AM
aidenrage's Avatar
aidenrage
7th Gear
Old Apr 30, 2015 | 10:34 AM
aidenrage's Avatar
aidenrage
7th Gear
this is the part, is it what yall are talking about? its on a telescopic and tilt column if that makes any difference
Old May 1, 2015 | 09:39 PM
Bob E's Avatar
Bob E
Hey, Yes, That must be the part! I was having the same problem as you. I purchased the lever (for tilt and tele) column. When I went to install it, I found the two wires for cruise are threaded into the column and the lever is just pushed into the column and you just pull on the lever to remove it. However----my problem didn't end there, when I signal a turn, the lever moves an inch or more before the mechanism engages. This loose play is only evident in one direction. When signalling in the other direction---it seems firm and works okay. I was considering a small amount of epoxy on the end of the lever. I supposed that the part might be worn and the lever is a sloppy fit. Any ideas?---I apologize if I am interrupting or butting in to this thread, I started out trying to help.--boB
Old May 5, 2015 | 09:39 AM
aidenrage's Avatar
aidenrage
7th Gear
hate to keep bothering you with this but i looked at the link but no parts come up, just takes me to the home page. do you happen to know what the part was called so i can look it up?
Old May 6, 2015 | 03:50 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
With the change in the website... also came a change in all the links. So what was good on the 20th is not a good link now. Here is the info you are looking for. The tech pictures for now... can all be found at http://www.repairs.willcoxcorvette.com
The pivot is not available new and I don't have any used. You'll have to search the part numbers below and hope you can turn one up.
Willcox.
http://repairs.willcoxcorvette.com/?...h+Pivots+78-82
To needing a little help!
