Old Apr 28, 2015 | 02:26 PM
CanadaGrant's Avatar
CanadaGrant
Default 69 427
I finally got the motor out. It turned out to be a ball bearing that punched a hole in number two piston. Where the hell does an eighth inch ball bearing come from...
I have the block and crank over at the machine shop. Cross drill the crank and have a set of Kieth Black forged pistons for it. The guy at the machine shop said, if you want to do this right, we should balance the clutch to the motor. I had never thought of that. Anyway, going with high end internals, a Comp near stock roller cam and still trying to figure out where the ball bearing came from. Check the hole... The top one is not supposed to be there and neither are the two indentations just above it.... That is a 45 year old from the factory motor and I really did not want to be the one to take it apart.
Old Apr 28, 2015 | 02:39 PM
bashcraft's Avatar
bashcraft
Sabotage?
What happens if you need to replace the clutch? Do you then need to rebalance the engine?
Old Apr 28, 2015 | 02:42 PM
forman's Avatar
forman
Looks like sabotage ,, the only way they get there is through the carb ,,,
Old Apr 28, 2015 | 02:52 PM
ddawson's Avatar
ddawson
Machine shop should leave a little room in the balance for future flywheels.
When mine was done they didn't want to zero it out with the flywheel for that reason.
Old Apr 28, 2015 | 03:07 PM
bashcraft's Avatar
bashcraft
How do you do that?
To do it right, the clutch and pressure plate assembly should have a neutral balance. That way it can be replaced with another one with a neutral balance without affecting the engine balance.
If a machine shop told me they wanted to balance the engine with the clutch on it, I'd pull everything out of there and go to a different shop.
Old Apr 28, 2015 | 03:08 PM
CanadaGrant
Originally Posted by bashcraft
Sabotage?
The internals will be balanced but I had never thought of looking at the clutch. It didnt even occur to me. Then the machine shop owner is talking about balancing, make everything smooth and Im thinking, all this work then bolt up a flywheel, clutch and pressure plate that isnt even close... Why balance something if you are going to throw it off.
Old Apr 28, 2015 | 03:19 PM
CanadaGrant
They told me they would like to balance the engine but figured it was important to have the flywheel, clutch, and bolts in order after they had done the crank, rods, pistons. I kind of like it. I used to own a shop that turned crankshafts and built race motors but never thought about the clutch assembly throwing off my work.
Old Apr 28, 2015 | 03:30 PM
bashcraft's Avatar
bashcraft
The clutch assembly won't throw anything off if it has a neutral balance.
Old Apr 28, 2015 | 03:47 PM
CanadaGrant
Well, I just pulled a clutch from Corvette Central and what you say is bs. Neutral balance is just a dream. You assume it has neutral balance but doesnt wash.
Old Apr 28, 2015 | 03:51 PM
bashcraft's Avatar
bashcraft
It needs to be balanced, but not with the rotating assembly.
I'll ask again, what happens if you need to replace the clutch? Do you then need to rebalance the engine?
Old Apr 28, 2015 | 03:59 PM
dochorsepower's Avatar
dochorsepower
Normally the flywheel, clutch and disk are balanced as a unit independent from the engine internals. Only externally balanced engines like the 454 and 400 require an externally balanced flywheel. If you are buying a clutch separately, yes it will have to be balanced, but as a set with the clutch disk and flywheel.
Old Apr 28, 2015 | 04:03 PM
dochorsepower
Almost forgot, the hole in the piston is a lightening hole.
Well if you don't believe that, it could be a ball check from the carburetor. If you had some rough running that could be the reason.
Old Apr 28, 2015 | 04:32 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you balance the flywheel with the rotating engine assy... always,
not the clutch assy.
you buy a balanced clutch assemble that should be balanced from the clutch manufacturer.
Old Apr 28, 2015 | 08:31 PM
CanadaGrant
What I am trying to say is that you go out of your way to balance a motor then just bolt up a clutch and pressure plate that probably came from China.
The engine will be balanced but I had never thought about the clutch. We all pay attention to the little things then forget about the other things. I checked the original clutch and it has four drill or balance marks in it so it was actually balanced at the factory. Will try and get a pic.
Ok. See the drill holes? I would balance the motor but had never thought about doing the clutch and would never think about doing it on the engine.
To 69 427
