Holley Dripping from Booster Venturi, Engine Bogs
Its a 350, stick, Dart alum heads, 225/235 roller, Victor Jr with holley 750 DP carb.
Got 72 pri jets, 6.5 power valve. 69 jets are too lean
Vac at idle is about 11-12
Does the large open plenum Victor make the carb see less vacuum...and/or is the power valve opening too soon? I bought the car this way, PO wanted a "racing" engine, and I know this part combo may not be the best. Thinking of going to 2.5 PV, need to make it more streetable.
Also want to dump the victor for a less tall dual plane manifold, hood barely clears w drop base air cleaner, suggestions?
Does the large open plenum Victor make the carb see less vacuum...or is the power valve opening too soon? I bought the car this way, PO wanted a "racing" engine, and I know this part combo may not be the best. Thinking of going to 2.5 PV, need to make it more streetable.
And a RPM air gap dual plane...
The airgap RPM will actually make more power than a Victor Jr. if the Victor is not port matched and runner entrances blended....
Out of the box...the Victor Jr. ports are tiny.
The RPM will "signal" the carb better than the Victor....but with a stick shift...I do not believe that is what is going on here.....
Jebby
Jebby
Yes I believe the 6.5 is a little heavy and opening a bit too soon....
I run 4.5's in 90% of my builds if they are lower than 11-12 inches of vacuum.....
I know what Holley says.....but it almost never works out that way....
Jebby
Hows the fuel level set, might be a little high?
Whats the idle rpm?
You have the list number for the carb?
Neal
That 750 DP is one awesome carb, but like anything, it has to be matched with the right components. Something the PO may not have done to optimum performance.
I agree that the Edelbrock is probably a better choice than that Victor. Not that the Victor isn't a good manifold, just not enough motor for that setup.
You may want to, at some point, put the carb back to stock as a starting point. Here are the stock configurations of various 750 Holley carbs.
4779 750cfm
Primary main jets 75, Secondary main jets 76, Power valve 8.5, Primary Nozzle 25, Secondary Nozzle 32
4779-1,2 750cfm
Primary main jets 70, Secondary main jets 80, Power valve 8.5, Primary Nozzle 28, Secondary Nozzle 31
4779-3 750cfm
Primary main jets 70, Secondary main jets 73, Power valve 6.5, Primary Nozzle 28, Secondary Nozzle 31
4779-4,5 750cfm
Primary main jets 70, Secondary main jets 80, Power valve 6.5, Primary Nozzle 28, Secondary Nozzle 31
4779-6,7,8,9 750cfm
Primary main jets 71, Secondary main jets 80, Power valve 6.5, Primary Nozzle 28, Secondary Nozzle 31
Replace your fuel filter (in case debris is holding the needle(s) off their seats) and reset your float levels. If that doesn't work, rebuild the carb and set everything to factory specs. BTW, your combination is mild enough that the carb factory settings should be very close.
Next problem, gas dribbling thru the venturis above idle, bogging: Tried changing jets from 72 to 69. Bad move, went back to 72. Did a 4.5 power valve swap, and started advancing the timing. Was at 10 deg, thought I was in the ballpark. But now at 20+ deg (plus a 17 mech), car runs like it should, no bogs, drips. Even in 5th (1-1) pulls smooth from 2000 rpm.
Next I need to check actual TDC and accuracy of timing marks!! Balancer is a new ATI but maybe the tab is off. Maybe tweek the dizzy a little more too, have kit from MSD.
So, timing + floats = success!
Thanks for all the inputs
Enjoy:
