Radiator Green Sludge
Old Apr 29, 2015 | 09:59 PM
99Problems's Avatar
99Problems
Default Radiator Green Sludge
Hello!
Last week I had my radiator replaced with a new Dewitts. I also had the the radiator hoses and water pump replaced when the new radiator went in. Yesterday was the longest drive I had taken it on since the replacement. I went to check the fluids and notice that radiator fluid leaked from the cap or the hose right under it. Not 100% sure which leaked. The reservoir was also low. When I pulled the cap off the radiator I saw this green sludge.
What could have caused this? Should I be worried?
Also, the car didn't overheat when I was driving it. I did use Prestone 50/50 in the yellow bottle and made sure not to use the Dex Cool when everything was flushed out and refilled. Did I screw up by filling it with the 50/50 Prestone? I didn't see any of this green sludge in the original radiator and it had 50/50 in that one too.
Old Apr 29, 2015 | 10:09 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Flush the system and use ZEREX and distilled water.
That crud could be a stop leak product used previously and the new coolant broke it loose.
Old Apr 30, 2015 | 01:06 AM
99Problems's Avatar
99Problems
I will do that, thank you for the reply!
To Radiator Green Sludge
