Electrical problem
Old Aug 14, 2002 | 01:31 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Electrical problem
if it rains I have to turn on the wipers, lights and air. it's ok at speed, but at idle volts drop to around 8 and the engine stalls. I'd like to add electric fans but that's asking for trouble I think. is the battery going south on me? I DID have to jump it when I first got the car
Old Aug 14, 2002 | 01:57 PM
71'AirStrike's Avatar
71'AirStrike
Default Re: Electrical problem (Markm10431)
I suggest that you replace the battery. Not many folks realise that when a lead acid battery deep cycels (goes completley flat.. dead.. KIA..paper weight) you will never be able to charge it back up to its full potenal amps and volts. I went through 2 batterys with AZ sun cooking teh water out, before I got a gell cell style battery.
if that does not work, then replace the alt.
good luck
