LT4 Crate Engine?
Old May 2, 2015 | 11:31 PM
68/70Vette's Avatar
68/70Vette
Default LT4 Crate Engine?
Does anyone know if a crate LT4 engine is available? This is the 650 hp supercharged engine in the 2014 and 2015 Corvettes. Of course, another question is...can you install this in a C3? I know that the motor mounts of the LT4 are different, so right away there's a little mod to get this engine onto a C3 frame. The next question is ...will a LT4 bolt up to a standard early C3 (...213) bellhousing? It would be just fantastic if it would. Anyone have any knowledge of anyone who's doing this conversion? I'm contemplating putting a big block in my 70, if I can get LT4 HP from what is essentially a small block..this is an attractive option since it's a smaller volume engine...I know that the engine cost of a LT4 may make me take a pass on this option.
Old May 3, 2015 | 07:42 AM
Gordonm's Avatar
Gordonm
It's not only the cost of the engine but all the other mods to put it in. Many here including me have done an LS swap into a C3 chassis. Yes you can bolt it in but al lot of other things need to be modded or fit. Adding a supercharger to the package makes it even trickier. No doubt it can and has been done but don't expect a weekend project. The BB is an easy swap. The LT4 takes a lot more.
Old May 3, 2015 | 08:59 AM
74modified's Avatar
74modified
I dont know if a crate version is available yet, but it would be not much different than a LS swap - that is fairly common. You would need the big 621 bell housing, but really, putting an "old tech" 4 speed behind the new engine would be taking it backwards. It would really be better with a modern 6 speed - that is commonly done with LS swaps. The big block would be much simpler, as the LT4 swap would need additional system upgrades - fuel, electrical, ect.
Old May 3, 2015 | 09:13 AM
Richard454's Avatar
Richard454
It really doesn't look that tough- exhaust manifold wouldn't work-AC compressor needs to be moved. HOWEVER-the price will probably be north of $20k!!!
Old May 3, 2015 | 09:25 AM
cagotzmann's Avatar
cagotzmann
The starting point for the LT4 is available as the LT1
GM Performance Catalog 2015
from the catalog
"2014+ LT1
Seventeen years after the second-generation LT1,
the all-new, Gen V-based LT1 engine debuted in the
2014 Corvette Stingray, where it helped the car sprint
from 0 to 60 mph in less than four seconds and cover
the quarter-mile in 11.9 seconds. It’s also the first LT1
to displace more than 350 cubic inches (376 cid/6.2L).
The Gen V LT1 shares architectural similarities with
the previous LS-series Small-Block, but with virtually
no interchangeable parts. It also introduced new
technologies to the Corvette, including direct injection
and variable valve timing. A supercharged
version of the engine dubbed LT4 – and
rated at 650 hp – powers the 2015
Corvette Z06,
making it the most
powerful regular-production
Chevrolet engine in history."
Old May 3, 2015 | 02:40 PM
lionelhutz's Avatar
lionelhutz
The LS9 crate engine is about $20k and I wouldn't expect the LT4 to be any cheaper if/when they are sold as crate engines.
Old May 3, 2015 | 06:03 PM
uxojerry's Avatar
uxojerry
The LT1 and LT4 are direct injection and run extremely high fuel pressure. A reasonable compromise would be a GM LSA.
Old May 3, 2015 | 06:13 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I wouldn't expect the differential of a C-3 to hold up under THAT kind of power....
Old May 3, 2015 | 07:41 PM
silvvette's Avatar
silvvette
Dang...... that is prettttttttyyyyyy!!!!!!
Old May 4, 2015 | 01:14 AM
GaToy's Avatar
GaToy
Man. Ya'll are talking mad play money. And here I am dreaming of a pathetic LS3. Wits a six speed or auto it would be well over $10 grand by the time I got it in. Because of it being a new engine and all your best bet would probably be to find a wrecked donor.
Old May 14, 2015 | 10:41 AM
GaToy's Avatar
GaToy
Was flipping through the new Jegs and saw they now offer a 6.2 LT1 for $8986.99.
Old May 14, 2015 | 11:00 AM
CanadaGrant's Avatar
CanadaGrant
And you can make huge power with this, and most other LS engines, with just a cam change, headers and a tune.
Old May 14, 2015 | 11:43 AM
Richard454's Avatar
Richard454
The fuel system to the engine is just a common 55 PSI set-up, similar to the LS. On top of the engine is the high pressure pump, driven off the cam...So really not that much of an issue.
To LT4 Crate Engine?
