Should Ignition and door key be the same?
Old Aug 14, 2002 | 05:37 PM
Swamp Thang's Avatar
Swamp Thang
Default Should Ignition and door key be the same?
For 1969, were the door and ignition key the same cut, or were they different ?
And, if you were re-keying all the locks in your car, what would you do?
Thanks.
Old Aug 14, 2002 | 05:43 PM
Mack's Avatar
Mack
Default Re: Should Ignition and door key be the same? (Swamp Thang)
Nope... Back then the round head key fit the door and the rectangle head key fit the ignition. The keys were different.
Old Aug 14, 2002 | 06:02 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Re: Should Ignition and door key be the same? (Mack76)
Old Aug 14, 2002 | 06:49 PM
Larry B.'s Avatar
Larry B.
Default Re: Should Ignition and door key be the same? (Markm10431)
The square key fits both doors and ignition on early cars. They changed in the mid seventie to using the round key for the doors. I think the change came in 74 ?? :D
Old Aug 14, 2002 | 06:51 PM
shoptek's Avatar
shoptek
My '71 uses the same key for door and ignition too.
Old Aug 14, 2002 | 06:53 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Mine's a '68, door and ignition same key.
Old Aug 14, 2002 | 07:03 PM
NHvette's Avatar
NHvette
If I were you, JR -
I'd drive that 69 right over to my work in Burlington MA.
Drop the car off, and I will install all the locks for FREE. :yesnod:
The job will only take 2-3 months to complete. :lol: :lol:
I like the single key idea. If you saw my 4-vehicle key ring - you'd know why.
Old Aug 14, 2002 | 07:07 PM
Tom73's Avatar
Tom73
The square head key worked the ignition and doors up through 73. The round head was the storage compartment, alarm, and spare tire lock. In 74 they changed to the round key also working the door and the square key working only the ignition.
tom...
Old Aug 14, 2002 | 08:15 PM
andyg's Avatar
andyg
My 69 same key.
Old Aug 15, 2002 | 09:19 AM
Mack's Avatar
Mack
Default Re: Should Ignition and door key be the same? (andyg)
I stand (sit) corrected. I won't post any more answers if I'm not sure. Glad there was somebody to correct me. :p: :yesnod: :D
Old Aug 15, 2002 | 06:23 PM
Larry B.'s Avatar
Larry B.
That's what the forum is all about....I have owned seven C-3's over twenty years and I just ate crow on some bad info I gave out on headlights.. :rolleyes: :D Seem that you never quit learning when it comes to these cars.
Old Aug 15, 2002 | 07:56 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: Should Ignition and door key be the same? (silvervetteman)
On my 72 square key does it all. :)
Old Aug 16, 2002 | 12:25 AM
ksbunting's Avatar
ksbunting
On my 68, the ignition and doors are the same, the octagon head key. The storage compartment and spare tire lock are a different key (the round key)
Old Aug 16, 2002 | 06:42 AM
thamzid's Avatar
thamzid
Default Re: Should Ignition and door key be the same? (ksbunting)
On my 81 Square key for Ignition and Round key for Door locks.
Old Jan 31, 2010 | 03:15 PM
78,00,69JRM's Avatar
78,00,69JRM
I have a 69 and the square key fits the two doors and the ignition. I will warn everyone though the new GM blanks do not work on the older corvettes. I spent a lot of time trying to figure out why new keys did not work in the ignition or doors and they were exact matches. Both old keys that were extremely worn did work. Look closely at the grooves in the keys. The new blanks the three grooves that go down the side of the keys are at least 1/4 inch shorter and the new keys/blanks will not work. I am not sure if anyone has the old type blanks but the ones I have seen and gotten lately have the short grooves. If you use a Dremel tool and grind out the grooves the keys will work every time. I wanted to replace my worn keys and it was a real problem so beware and look at the blanks real close.
Old Jan 31, 2010 | 03:44 PM
oldsarge's Avatar
oldsarge
Originally Posted by NHvette
If I were you, JR -
Me too. I have 1 door, 1 ignition. 1 tire carrier and 1 for the alarm. One key would be nice, even two.
Old Jan 31, 2010 | 05:15 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the two different keys was just another stupid move by GM and every day i get in my pontiac i think how stupid it is.....
To Should Ignition and door key be the same?
Old Feb 1, 2010 | 09:34 AM
MrJlr's Avatar
MrJlr
tom...
My '74 uses 2 keys.
Old Feb 1, 2010 | 10:15 AM
bleppek's Avatar
bleppek
My '69 uses 2 keys and also mentions 2 keys in my original owner's manual. Square for ignition and door lock, round for all other locks.
Old Feb 1, 2010 | 01:26 PM
Ravine Speed's Avatar
Ravine Speed
No so fast, slick. On the '69, the square GM key works on the door locks and the ignition, the OVAL GM key works on locking rear compartment and tire carrier. The totally different small ROUND key works on the alarm system, if so equipped. 3 Keys, potentially.
