humming...
Old May 5, 2015 | 07:04 AM
ArthurfromHolland's Avatar
ArthurfromHolland
Cruising
Default humming...
as most of you will recocgnize, driving your Vette for a while makes you aware of her typical noises and behaviour. things that a mechanic may not even hear or feel.
the noise I am currenly working on after solving the diff issues is a humming sound only when I cruise. when releasing the gas pedal its gone right away.
does anyone ever had the same noise and was able to solve it? or does anyone have the knowledge to do a root-cause and may have a clue?
appreciate your help and comments, as always.
kind regards from a Vette loving country!
Arthur
Old May 5, 2015 | 08:00 AM
JimLentz's Avatar
JimLentz
Manual or automatic? Is the noise coming from the front or rear of the car?
Old May 5, 2015 | 09:27 AM
ArthurfromHolland
Cruising
U r right!
77 automatic.
noise is from the rear
Old May 5, 2015 | 09:35 AM
JimLentz's Avatar
JimLentz
Sounds like the gears in your differential. I had a manual transmission like that, but it never gave me any troubles.
Old May 5, 2015 | 10:08 AM
ArthurfromHolland
Cruising
thanks Jim! Ive had the diff overhauled some months ago since it was making a hell of a noise after driving it for 45minutes or so...maybe worth while having it checked...
Old May 5, 2015 | 10:21 AM
JimLentz's Avatar
JimLentz
Does the sound also go away if you give it a bit more gas?
Old May 5, 2015 | 01:00 PM
ArthurfromHolland
Cruising
not sure, since if I do the pipes get the upper part...
To humming...
