'68 Temp Gage Correct Installation?
Old May 6, 2015 | 08:27 PM
Too Slow '90's Avatar
Too Slow '90
Default '68 Temp Gage Correct Installation?
I forgot the orientation of this and want to be sure it is installed correctly. It is the upper left gage. From what I recall the flat tab attaches the left and right terminals and sits below the plastic connector attaching the top and bottom terminals. Is it correct as installed? I have one lock washer left over (after I used 4 on the terminals) and wonder if it is supposed to be used as a shim somewhere. Thoughts?
Old May 6, 2015 | 09:38 PM
TOM B1's Avatar
TOM B1
I looked at my spare I have and you have it correct.
the 4 nuts all have a washer under them but the center terminal with just a nut,, (no leg) has a washer under the white plastic to contact the base.
Old May 7, 2015 | 06:08 AM
Too Slow '90
Thanks.
Old May 7, 2015 | 05:36 PM
ddawson's Avatar
ddawson
Top and bottom are fine. Left and right.
Right side should have a non conductive washer under the resistor. Left side does not.
See this page. 1968-1976 Corvette Temperature Gauge Assembly
http://repairs.willcoxcorvette.com/?s=gauge
Old May 7, 2015 | 09:20 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Old May 8, 2015 | 06:31 AM
Too Slow '90
Thanks for responding. I had the non conductive washer on the wrong stud.
Old May 8, 2015 | 06:32 AM
Too Slow '90
Thanks.
Originally Posted by Willcox Corvette
To '68 Temp Gage Correct Installation?
