Charging question
Old May 6, 2015 | 11:12 PM
allena's Avatar
allena
Default Charging question
Hi all
I have a 75 veto with ac & auto
I checked my charging rate while my engine running & no accesories on
The multimeter showed 12Volts, is this right?
It has the original hei ignition system on it.
Also when driving with the lights on, the ammeter gauge shows a little
on the negative side 3 or 4 amps. But without the lights on it's on 0 amps
Is this ok? or should I replace the alternator.
Thanx in advance
A
Old May 6, 2015 | 11:47 PM
vbgod1's Avatar
vbgod1
Just sitting on the shelf, a battery should have 12.6 volts available. When the car is running, I look for about 14.2 volts, that tells me it is charging. Don't automatically condemn the alternator, it could be a loose wire, loose belt, even a bad ground. I think most parts stores will do a free charging system test for you.
Old May 7, 2015 | 05:57 AM
Haggisbash's Avatar
Haggisbash
Do you have the separate regulator? On my car lack of charging was traced to a loose connection on the regulator.
To Charging question
