Timing Chain Cover Clearance
Old May 9, 2015 | 03:33 PM
wheatpj's Avatar
wheatpj
Default Timing Chain Cover Clearance
Is there enough clearance for the factory timing chain cover to clear a Comp Cams double roller timing chain? The engine is a 71 454 LS5.
Old May 9, 2015 | 04:18 PM
mikem350's Avatar
mikem350
Most aftermarket chains are made to work with OEM covers. I think you are OK.
Old May 10, 2015 | 09:30 AM
wheatpj's Avatar
wheatpj
Okay, I'm going for it. I guess I will fit it, and crank the engine over by hand and see if it clears the cover.
Thanks Pat
To Timing Chain Cover Clearance
