Rear Compartment
Old Aug 15, 2002 | 06:16 AM
sped01's Avatar
sped01
Default Rear Compartment
Last summer I blew a half shaft on launch and it went right thru the battery box. I wanted to know where or what I can do to replace it. I tried one shop but they wanted over $200 to fix it. It is prob 6inby6in hole. I was curious as to which method you guys would use to fix it. I was wondering if a fiberglass fill would be a good idea or if there is a part made to fix this. I was also thinking of just buying a battery box. Any thoughts would help. It is a 79' vette. Thanks
Old Aug 15, 2002 | 06:23 AM
Mystery Machine's Avatar
Mystery Machine
Default Re: Rear Compartment (sped01)
Not that I think Ecklers is the best place to buy stuff (Capitalist pigs! :) ) but they have some stuff that is tough to find elsewhere:
http://www.ecklers.com/dept.asp?dept%5Fid=213
Old Aug 15, 2002 | 10:07 AM
Tom73's Avatar
Tom73
I don't think you can just buy a battery box, isn't it all one piece, part of the floor of the rear compartment. For a 6 x 6 hole I would just glass it in. Is it on the flat surface? If so would be very easy to lay glass mat to repair. It it goes around a corner you may have to make some type of mold to get the contour right.
tom...
Old Aug 15, 2002 | 11:38 AM
bl75vette's Avatar
bl75vette
Had a similiar problem, the battery must have leaked acid and ate away 1/3 of the bottom compartment. The previous owner cut a oak board to conform to the bottom and rested the battery on it. I was quite concerned when I was purchasing the car since I had no fiberglass experience. I however bought a can of fiberglass resin and cloth at home depot. I laid up 3 layers of resin and cloth. It cures very quickly, so you can do the whole job in a couple of hours. Just make sure you have adequate ventilation, and were gloves. Good luck!!
To Rear Compartment
