C3 Divirter Valve
Old May 15, 2015 | 04:50 PM
mnenichka's Avatar
mnenichka
7th Gear
Default C3 Divirter Valve
Is it possible to check correct operation of Diverter Valve #7029199
off the car. should the vacuum port hold vacuum when checked with a vacuum pump. Should you see the diaphragm move in the port cavity ? Any help would be appreciated.
Old May 15, 2015 | 09:49 PM
dugsgms74's Avatar
dugsgms74
Yes and yes. When vacuum is applied to the port the spool valve should move. I wouldnt be surprised if it was bad, most are. If it is you have a few options. 1.send it out for rebuild, I looked into doing this my self and it is possible but as far as I can tell youd need to make a took to re-crimp a new top on and the amount of effort it would take to design/make the tool that make a nice crimp kinda makes it not cost/time effective. 2. run it as is and deal with a bit of backfiring on decel. 3. devane the pump and and plug the lines where they go into the exhaust manifolds(thats what I did).
