Rocker panel bolts?
Old Aug 15, 2002 | 05:39 PM
Shaggy's Avatar
Shaggy
Default Rocker panel bolts?
I've got broken bolts, how can I remove the thread insert and replace?
Old Aug 15, 2002 | 05:58 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Re: Rocker panel bolts? (Shaggy)
an EZ out MIGHT work. probably end up drilling and tapping though
Old Aug 15, 2002 | 06:00 PM
1LE's Avatar
1LE
Had to drill mine.
Old Aug 15, 2002 | 07:13 PM
Shaggy's Avatar
Shaggy
Default Re: Rocker panel bolts? (1LE)
After drilling, did you re-tap the thread or is there an insert available to install?
Old Aug 15, 2002 | 07:25 PM
Paul L's Avatar
Paul L
Why not just get a rebuild kit? They are not expensive. This is from Dr. Rebuild's catalogue.
Old Aug 15, 2002 | 07:26 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
I got a replacement that bolts on where the old one uded to be.
You drill it out larger and it is like a bolt and a nut thing, pretty slick!
Old Aug 15, 2002 | 08:37 PM
Shaggy's Avatar
Shaggy
Thanks for the help/ Looks like I need to feed the nuts up from behind and hold them until the bolt is tight. Is that correct?
Old Aug 15, 2002 | 11:16 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Notr sure if it's correct or not, but that's what i had to do. The whole time I was wondering how they got away with anything like that in a production environment.
Old Aug 17, 2002 | 03:39 PM
Paul L's Avatar
Paul L
I believe that is correct. It has been a while since I did that job. I simply used #8 or #10 SS machine screws with WD-40 to avoid any future corrosion. When I had my car painted in 2000, the paint shop was amazed that the screws came out easily without a fight.
To Rocker panel bolts?
