Front bushings
I've been looking at Vette Brakes and Products. Has anyone used their poly? Are their rubber made by MOOG?
460 springs, Borgeson steering, Blistien shocks, spreader bar, now the handling limit is the tires.
If you wish to reduce CA bushing compliance versus rubber in a less than racing application, poly will do that. But, be aware that typical poly must be properly lubed upon installation and periodically thereafter. Squeaking poly is binding poly, and binding stiction is NOT your suspension's friend. Also, poly CA bushings w/o serrated sleeves require monitoring and periodic re-tightening. FWIW, I do not happen to favor poly for linkage points such as camber struts or TA bushings which don't simply move about a fixed axis.
TSW
TSW
Yes, at points that move in "3D" I would recommend heim-jointed camber struts (and w/ lock plates in lieu of eccentric adjusters), as well as sphericals or Johnny Joints for the TAs, over rubber or poly. That said, I'd suggest those who don't wish to go that far should just stick with fresh rubber at those particular points rather than to consider simple (read, "2D") poly bushings.
