Broke Something in the rear
Old Aug 15, 2002 | 10:26 PM
Ratty82's Avatar
Ratty82
Default Broke Something in the rear
Thought I was having tranny problems until we lifted the back end off of the ground and put it in gear. Sounded like a big trash compactor. Could it be something simple (NOT)! Any ideas before I take it in to the shop?
Old Aug 15, 2002 | 10:42 PM
Gordonm's Avatar
Gordonm
Default Re: Broke Something in the rear (Ratty82)
If it sounds like it is inside the pumpkin it is probably the spider gears. Could be the cross shaft broke or if you are like me the ring gear bolts. This would not allow the car to move at all. Sounds like you need to pull the pumpkin out. You will save some money if you can deliver just the pumpkin to the shop. A lot of the cost is removing the unit out of the car. It is not hard just time consuming.
Old Aug 15, 2002 | 10:44 PM
NHvette's Avatar
NHvette
That sux.
It sounds like you might want to swing by the bank, before heading to the shop. :D
Hopefully, it might just be a u-joint or two. :yesnod:
Can you tell where the sounds come from ?
Good Luck
:seeya
Old Aug 19, 2002 | 12:02 PM
Ratty82's Avatar
Ratty82
Thanks for the replies guys. The noise is definately coming out of the rear end and not any of the universal joints. I noticed the Zip has rebuilt rears for $579 with a 3 year warrenty. I may stop by the place just to see what they have in stock. This may be a good time to replace the 2.73s.
Tony
Old Aug 19, 2002 | 12:05 PM
Fevre's Avatar
Fevre
ZIP charges extra for non matching gear swap.
To Broke Something in the rear
