Front Wheel Hub/Rivet
Old May 31, 2015 | 02:15 PM
Mereness's Avatar
Mereness
Default Front Wheel Hub/Rivet
OK.....So I drilled out my rivets enough to get my front rotor off of the hub on my 78. After I pulled the rotor off I noticed that I have the remaining rivets poking out enough to interfere when I place the new rotor on. How do I get the remaining rivets out of the hub without doing damage to the hub? And yes what is the easiest?
Thanks!
Old May 31, 2015 | 02:21 PM
toobroketoretire's Avatar
toobroketoretire
Thanks!
You'll have to grind the extra rivet material off the face then drive them out with a 5/16" flat punch. They'll come out hard because they are swelled to fit the hole (like rivets are supposed to do)
Old May 31, 2015 | 02:45 PM
BOOT77's Avatar
BOOT77
idk if it's the same on the front as I never removed my front rotor from the hub, but the rear I used an air chisel to drive the rivets out.
Old May 31, 2015 | 04:23 PM
ajrothm's Avatar
ajrothm
Just take a center punch and hammer the rivets out from the front (rotor side of the hub). They'll come right out, I just did mine a couple days ago. The drilling part was way harder then knocking out the remainder of the rivet.
To Front Wheel Hub/Rivet
