alternator rattle
Old Aug 16, 2002 | 11:43 AM
bourne62's Avatar
bourne62
Default alternator rattle
I've got a rattle coming from the front of my motor, sounds like bearing starting to go. Problem is I can't pinpoint where it's coming from. Can I remove the alternator or the air pump belt and still get the car to start?
Old Aug 16, 2002 | 02:44 PM
72GACRZR's Avatar
72GACRZR
Default Re: alternator rattle (bourne62)
you could try the old broom stick in the ear trick. Use a cut off broomstick or big long screwdriver and with engine running (use caution around moving parts) put end on alternator (etc) and lean down and put your ear on the other end, if bearings are bad you will hear a lot of noise. try different units to gage differences in sound.
Old Aug 16, 2002 | 02:59 PM
bourne62's Avatar
bourne62
Default Re: alternator rattle (72GACRZR)
Broomstick handle, hmmm, sounds like another one of those overpriced specialty tools that you only need once.
Old Aug 16, 2002 | 08:59 PM
Steve Grodin's Avatar
Steve Grodin
You can remove both belts and start the car. No noise you know it is on or the other. If you still have a noise you know you have to look further. You can use a length of hose as a stethoscope.
To alternator rattle
