I can build a whole damn car but installing the outer window felts are kicking my ***. The widow is installed so elongated the holes for the pins is not an option. Then trying to press them in with the window in is a @##. I was thinking of shavings some of the tabs, I can get the front two in and the last one sorta but that's it. Any ideas are welcomed,thanks
I got a set from Ecklers a couple of years ago, they didn't fit right, nothing lined up, tried a different set, same issue. Ecklers worked with me and refunded the cost of the parts. Got a set from Willcox, snapped right in.
When the good (and they are not always perfect) repro's were not available, we'd get the generic wipes and modify them as needed. By generic I mean the rubber wipers with no hair type that were made by PUI.... at the time it was all there was available.
We would first cut off about 2/3rds of the rubber wipe (it was too long and would actually slow down the power window motor so much,, the glass wouldn't roll up). Then we would use a die grinder and cut down the width of the retaining clips to which ever side they needed it. In most cases the clips would be within 1/8" of making it in the hole so we would just trim off 1/8" or a tad more from that one clip and roll on with it. If screw or rivet was needed to retain the clip (sounds nuts but it is also true), we had a stop plug on the drill to make sure we didn't penetrate the door skin in error.
My new wipers wouldn't line up on all holes so I removed the pins that didn't (they were crimped to the wiper rail) drilled new holes for them in the correct place and then crimped them back in place, worked perfectly.
Maybe this is an option for you....
Willcox
That was exactly my next plan. As always many thanks
