Help please. Both power windows quit working.
There is a power window relay under the center console so you might start there (after checking all of your fuses).
Next go under the hood and make sure that you have 12 volts into and out of the circuit breaker.
Still not working? Now check for 12 volts at the relay.
Scroll down for the power window schematic:
http://www.vetteprojects.com/bmv/mis...tte%201977.pdf
Are the gauges and pw on the same fuse? It looks like the one that's blown says gauges on it. I jumped across it and the PW worked though.
and below is a schematic for a different year, but the tech help in this picture is pretty much the same for your car. Pay attention to (A) Under No deflection too... always check to make sure the power window harness is plugged into the fuse panel and making good contact before you tear anything apart.
Willcox
Also, checking out continuity, circuit problems, etc in a car using the car battery is not prudent. The battery can pump out 600 amperes. If you have a potential circuit problem, good luck if you blow a fuse. If the circuit problem is not protected by a fuse, the battery can produce massive electrical damage. After making extensive changes to my 68's electrical system, I first energized up the electrical bus with 12 volts supplied by a pack of small dry cell batteries..every thing was off so there shouldn't have been any power drain except for the clock...no problems. Next I used a 12 DC power supply good for 10 amperes/15 amps surge. With the 10 amp power supply I could operate most of the electrical circuits in the car...no problems...then I connected the bus to the battery...no problems.
My apologies if I'm too preachy!!!
