wheel spacer for front disc????
Old Jun 3, 2015 | 11:29 AM
mirage2991's Avatar
mirage2991
Default wheel spacer for front disc????
My fromt rotors must use a spacer between the hub and them in order for the caliper to fit on my 68. Stock front calipers
Washers are also used between the caliper bracket to center it onto the rotors.
if the spacer is not used then the caliper will comtact the rotor...
Perplexed... they didnt need a spacer with stock rotors... what gives?
Old Jun 3, 2015 | 11:38 AM
wombvette's Avatar
wombvette
Got the wrong ones. Front and rear are different.
Old Jun 3, 2015 | 11:39 AM
toobroketoretire's Avatar
toobroketoretire
You need to compare your old rotors with these new rotors to see what changed. If the dimensions are the same you shouldn't need spacers...............
Old Jun 3, 2015 | 11:53 AM
The13Bats's Avatar
The13Bats
I thought brakes, caliper and rotors were the same 65-82?
Old Jun 3, 2015 | 11:55 AM
toobroketoretire
The rear rotors have a parking brake drum in them....................
Old Jun 3, 2015 | 12:01 PM
The13Bats's Avatar
The13Bats
I realize they differ front to rear...
He was talking about the fronts..which look aftermarket.?
Old Jun 3, 2015 | 12:04 PM
wombvette's Avatar
wombvette
They are the same blanks but are machined differently. The flange is a different thickness which if switched, throws the rotor out of position.
Old Jun 3, 2015 | 12:05 PM
Garys 68's Avatar
Garys 68
Wait, are you saying the rotor is spaced outward using the spacer. Then the caliper is spaced outward using washers?
What happens if you remove both the spacer and washers?
Just wondering if the spacer was added due to larger wheels used in the past.
Old Jun 3, 2015 | 12:11 PM
redvetracr's Avatar
redvetracr
the above pic is of a rear rotor, it has two extra holes that front rotors do not have.
Old Jun 3, 2015 | 12:14 PM
The13Bats's Avatar
The13Bats
Okay...looked off to me, I wasnt that savvy...rear rotor on front doesnt work?, so the spacer ring I thought that goes between the wheel and rotor in most cases?
Old Jun 3, 2015 | 12:26 PM
Aggitated Monkey's Avatar
Aggitated Monkey
You have parts miss-matched. I have never seen spacers between the hub and rotor and I have never seen spacers for the calipers. Every thing should bolt on, with no alignment problems, if you have the correct parts. Front and rear are different. The rear rotors have the extra hole for adjusting the parking brake. The spacer innyour photo are non-centeric spacers for adjustingnback space clearance with wheels. DO NOT put those behind your rotor.
Old Jun 3, 2015 | 01:40 PM
mirage2991's Avatar
mirage2991
ok my mistake the "rears" which are the front do fit fine... i have no idea why they were put on to the rear... all better now
To wheel spacer for front disc????
