1979 Rad-Which One?
Old Aug 16, 2002 | 08:09 PM
Paul L's Avatar
Paul L
Default 1979 Rad-Which One?
I guess it is time to get a new rad. I can fool about with T-stats, flushes and the like but the fact remains that my rad is 24-years-old. All is well for the moment but this will become a winter task. I can source an original, discontinued 1979 rad from GM for about $180.00US. There are several in GM depots in the USA. But the questions boggle the mind. You see this in Corvette catalogues:
-1 1/4" or 1 1/2" inlets?
-L-48 or L-82?
-A/C or not?
-HD or not?
-HD without A/C? Except for the L-82?
I am making the assumption that the 1979 L-82 without A/C has a HD rad. It certainly does have a 1 1/2" ID diameter on the hoses. Is that a reasonable assumption?
Old Aug 16, 2002 | 08:51 PM
Pete79L82's Avatar
Pete79L82
Default Re: 1979 Rad-Which One? (paul79)
Paul:
If you look in the GM parts book there are a lot of different choices but they all work out to 2 different part numbers if you have 1 1/2" inlet.
They are
Part # 3055558 for L48 with or withput A/C
Part # 3055556 for L82 with or without A/C
There is a metal tag welded to your radiator about half way down on the right side, it should have a tag code of "ML"
Late 76 through early 79 used the 1 1/2" radiator neck, Late 79 through 82 used the 1 1/4" neck.
Old Aug 16, 2002 | 09:36 PM
Paul L's Avatar
Paul L
Default Re: 1979 Rad-Which One? (Pete79L82)
Thanks Pete. I did not look too hard but I cannot find that tag. But the ID of the hose is definitely 1 1/2". I have those hoses in the basement and did the measurement. So it looks like 3055556 which is the one that is still available. many thanks!
Old Aug 16, 2002 | 09:43 PM
Pete79L82's Avatar
Pete79L82
The tag on mine is in a position that is pretty much unreadable in the car. It is just about in line with the front of the right upper control arm. With A/C you can't see anything there.
Old Aug 16, 2002 | 09:53 PM
Paul L's Avatar
Paul L
I will try again tomorrow when I have better light!
Old Aug 17, 2002 | 12:06 AM
KENS78SILVERANNIV's Avatar
KENS78SILVERANNIV
You're right... the L-82 probably has the heavy duty radiator. I installed a 4-core Modine... (heavy duty) for under $225.00. Made a world of difference and now I don't even think about cooling problems. :cool:
Old Aug 17, 2002 | 03:26 PM
Paul L's Avatar
Paul L
Default Re: 1979 Rad-Which One? (KENS78SILVERANNIV)
I think the rad with the 1 1/2" inlet is correct. I can't find a tag but as noted, GM parts numbers come down to two choices. And the other is 1 1/4" which I do not have.
Old Aug 17, 2002 | 04:52 PM
1yy07's Avatar
1yy07
Go get a Modine your part#718 I think they are a goooooood radiator, really tough. Try it youl like it. :smash:
Old Aug 17, 2002 | 06:34 PM
Paul L's Avatar
Paul L
Default Re: 1979 Rad-Which One? (1yy07)
I am sure they are a very fine product! Thank you for the reply. But I get a discount at a GM dealer and I would like to keep close to stock.
To 1979 Rad-Which One?
