Please help! Header diameter too big?
Old Jun 9, 2015 | 11:38 PM
TanksFull's Avatar
TanksFull
Default Please help! Header diameter too big?
Hello all. Shop has just finished my 350 vortec engine.
My mechanic was about to install the header/sidepipe combo when he calls to tell me that the header tube diameter is 2 inches which he says is way too big and will kill performance. In his words "like trying to run with a bag over your face".
The header/tube combo is a maximizer set(obx) that many here have used. The actual diameter is 1.9. Hes telling me 1 5/8 is most I should use. He's also worried about the gasket sealing.
Any opinions from those running obx header/sidepipe or with performance c3s is welcome.
link to headers
http://www.ebay.com/itm/171794324739?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Jun 9, 2015 | 11:56 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I doubt it's 2"..maybe 1-7/8"? That is pretty big for a stock 350....but they are awful long so that will help low/mid range.
Hey....you'll be ready for that nasty 383-406 you really want later on!
JIM
Old Jun 9, 2015 | 11:57 PM
cooper9811's Avatar
cooper9811
Lots of us have run these or Hooker side pipes with mild or even stock 350s. The closer to stock you are, will cost you some low end torque but it's not huge. I ran them on a vortec-headed 355. I still had fun.
He is right that those headers are not an ideal primary tube size for a 350 but not unusual for these cars.
Install'em and keep upgrading until you are running a big cubic inch stroker to fill up that header...
Old Jun 10, 2015 | 01:24 AM
mikem350's Avatar
mikem350
I think the mechanic balked because of how close the bolts are to the header pipes...lol
Seems like a good price for the complete setup!! Let us know how you like them.
Old Jun 10, 2015 | 06:35 AM
waljr's Avatar
waljr
There's a header calculator at wallaceracing - http://www.wallaceracing.com/header_length.php
Hope it helps
I'll tidy the link up a when I'm not on my phone.
Old Jun 10, 2015 | 10:40 AM
REELAV8R's Avatar
REELAV8R
I run the 1 7/8" headers with side pipes. The only size they come in from hooker. 350 CI engine. Ran fine stock and now modded @ 377 HP. You may need some jetting adjustments depending on which inserts you get.
Some performance may be missing, but the cool factor is all there. Get a higher stall torque converter if you want to get a better launch. Mine stalls @ 2600. That and a shift kit for the Th350 make it a lot of fun.
Old Jun 10, 2015 | 12:12 PM
Shark Racer's Avatar
Shark Racer
IMO they'll still meet or beat the low end torque available w/ ram's horns. And certainly decimate them at mid-range and top.
Old Jun 10, 2015 | 01:53 PM
mikem350's Avatar
mikem350
Old Jun 10, 2015 | 05:07 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
The listing that was posted, says the header primaries are 1.9" Overall Diameter. This translates to approximately 1.75" ID, which is the dimension you should be concerned about. A "street" header would possibly be better at 1.625", but in all reality, I wouldn't quibble over it.....
Old Jun 11, 2015 | 10:12 PM
TanksFull's Avatar
TanksFull
Thanks guys.. Getting a bigger better engine is not an option. I just paid for this new engine and it would not make sense.
Are ALL the side pipe headers going to be 1 7/8?
Old Jun 12, 2015 | 12:15 AM
cagotzmann's Avatar
cagotzmann
link to headers
Maximizer Header Amp Resonated Side Pipe 63 82 Corvette C2 Amp C3 Stingray SBC V8 | eBay
I have some Sanderson Short Headers for my zz383 vortex d shaped exhaust ports. Speaking with the Manufacture my 1 3/4" tubes are difficult to build to seal properly when the vortex ports measure 1.5 x 1.5 approx. So the flange design is the important area to determine if they will seal or not. If they dont account for the port size on the head it is possible they wont seal properly. Compare the exhaust port size and shape to the header flange size, this will tell you if leaks may be a possibility.
Old Jun 12, 2015 | 01:34 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
SB Corvette sidemounts have had 1.875" OD x ~45" long primaries as long as I can remember. And I made a point of posting that latter dimension. IMCO it would be a mistake to overlook that primary length is just as important in header design as diameter. It helps to think of primary diameter as locating the fulcrum, and primary length as how much weight is on each end of the lever. So, while in theory a shorter primary of only 1.625" OD may locate peak TQ nearer to your intended target, it is entirely possible that the long-tube sidemounts could put more TQ under the curve within your intended performance RPM range. And, at the end of the day whatever you put aft of the collectors could well compromise whatever is ahead of them anyway.
In any event, assuming that you're not racing for serious money or you wouldn't rely on asking the interweb, I'd relax and install the sidemounts if that's your preference. Besides, you'd think if they were all that far off for most applications that someone would have gone back to the drawing board after all these decades, no? FWIW, the BB ones are 2.125" OD, and none of the 427s I've built have lacked for TQ/HP. My $.02
Old Jun 12, 2015 | 07:52 AM
Cavu2u's Avatar
Cavu2u
My Blackjacks:
The 383 will eventually feed into these:
Steve
To Please help! Header diameter too big?
