69 Quadrajet Question
Old Jun 13, 2015 | 11:30 AM
CanadaGrant's Avatar
CanadaGrant
Default 69 Quadrajet Question
On a 69 divorced choke Quadrajet 7029215 there are three vacuum ports and all are manifold vacuum. There is the main EGR port, and one beside it with the third port being a tube on the pass side through the choke linkage. The smog pump is hooked to one and the vacuum advance is hooked to the other. Is the distributor hooked to the side or front port? It probably doesn't matter but was wondering what the factory setup was.
Thanks guys!
Old Jun 13, 2015 | 01:06 PM
Revi's Avatar
Revi
Front driver side, small vacuum port - Distributor vacuum advance
Front lower center, large vacuum port - EGR valve
Front passenger side, small vacuum port - Choke pull-off
Right passenger side, small vacuum port - A.I.R. Diverter valve
Old Jun 13, 2015 | 01:11 PM
dugsgms74's Avatar
dugsgms74
From the factory the distributor ran off the front(ported) and the smog pump off the side one(full vacumm). A better set up is to run both off the side one.
To 69 Quadrajet Question
