New Smeding 383 Touring in 75. Quick Fuel 680 carb with PCV valve connected where brake booster was connected. Edelbrock
Performer intake with 1 vacuum connection. Right now the Brake, 400 trans and headlight vacuum are all tee'd off the single manifold port.
The brakes don't feel like normal and I have to turn the headlights on at noon to have them open by dusk at 8:45 PM. The trans works just fine.
Carb has 2 vac ports and the advance is connected to full vac.
Any thoughts on other connection options??
Stump
Disconnect all vacuum lines except the distributor and the headlights, and then test the headlight operation. If that's OK, reconnect systems one at a time to check for leaks. If it turns out to be a simple lack of vacuum capacity, try connecting the PVC to the air cleaner, and the brakes to the rear carb port.
The brake booster should be on a vacuum source by itself. The stock position was the base of the Quadra-Jet. Nothing should be using this source other than the booster.
Brakes rear port of carb,
You can use the front vacuum port for PVC and tank Vacuum - operate headlight ... etc.
