'74 horn button issue
Old Jun 14, 2015 | 05:14 PM
ts_vette_st's Avatar
ts_vette_st
Default '74 horn button issue
The PO spliced onto the horn wire under the dash and mounted a button by the emergency brake. I want to fix the button. I pulled the cap off to see how it looked. not sure I see how the horn works. It looks like most everything is there but I see no wires. Anyone have any pointers or pics of horn wiring? Thanks.
Old Jun 14, 2015 | 05:34 PM
johnt365's Avatar
johnt365
They sell these horn repair kits. Do any of the pieces below look to be missing or worn out?
Old Jun 14, 2015 | 05:43 PM
ts_vette_st
I have all those parts except the pin and spring. Unless that is the pin below the leg sticking down from the ring. I don't see anywhere that the wire going up the column connects. Is it below the wheel and telescopic column?
Old Jun 15, 2015 | 10:04 AM
Peterbuilt's Avatar
Peterbuilt
Old Jun 17, 2015 | 01:28 PM
kcochran's Avatar
kcochran
Cruising
How it works:
The cover clips onto the largest of the parts shown above. That part is actually a few parts, particularly it is two pieces of metal with a cardboard isolator all tied with three white plastic rivets. One of those pieces is against the spring pin with a leg, the other is chassis bolted to the column. If those parts touch, the horn goes off.
My original, the plastic pieces were mushed as if Dwayne Johnson was the previous owner. The replacement was a little bent up too and took me ages to get it to stop shorting out. I've also heard that people sometimes need to take them apart and polish them to get steady contact?
I found lots of guides but nothing that actually explained how the horn switch worked, took playing with the replacement to figure it out!
Old Jun 17, 2015 | 01:51 PM
Peterbuilt's Avatar
Peterbuilt
Default A to B
You can not see the black wire from the top of the steering column because it is inside the column with the rest of the turn signal wires.
At the bottom of the steering there is a 'harmonica' connection.
Open the connection. On the half that goes to the car apply a ground to the black wire at "G".
If the horn blows then everything from there forward is good. If not go back to Willcox's 'how to'.
Next check the other half of the harmonica connection, (the part going up the column) check for continuity from 'G' to the horn contact (Willcox 'A').
If no continuity then the wire inside the column is bad.
Old Jul 25, 2015 | 08:02 AM
ts_vette_st
Got distracted with life but finally checked this. No continuity from A to the bottom of column. Next question any tips on pulling the wheel to check wiring in column? Assuming using the two threaded holes on either side of the post to pull the wheel? (lower right corner of Wilcox pic by A)
Old Jul 25, 2015 | 08:18 AM
'75's Avatar
'75
You could do a google search for Jim Shea, he has all the info you need for steering columns.
To '74 horn button issue
