74 starting issues
Old Jun 14, 2015 | 07:11 PM
chrisNY's Avatar
chrisNY
Default 74 starting issues
hi everyone, I am having a issue with the 74 I am restoring, its a factory 4 sp, and for some reason every few days when I go to start it, it wont turn over, its like when I push the clutch its not letting it start, but I was working on the fixing some gauges, so had the center cluster pulled and had a meter on the clock wire because its always hot, and when it does this, the voltage on the hot wire, drops from 12, to 5v, and everything else wont work either when it doesn't engage the starter, sometimes it will start again when I play around in the fuse box, but haven't found exactly what's going on, tonight it done it and for the life of me I cant get it to go now. can I bypass the clutch engaged and start it?? if so what do I need to do? or has anyone else come across something like this? thanks
Old Jun 15, 2015 | 11:32 PM
FirebladeDan's Avatar
FirebladeDan
Is there a noise associated with it attempting to turn over? If absolutely nothing happens at all check that your starter is getting 12v. Per the clock wire I would leave it as an open. That way it doesn't have a draw to whatever else it might be touching/grounding itself to. I'm suspecting that your starter was being a turd and needs to be replaced.
Old Jun 15, 2015 | 11:56 PM
chrisNY's Avatar
chrisNY
No sound at all, when it happens
Old Jun 16, 2015 | 12:25 AM
FirebladeDan
I was hoping it was a noise.
What I would check before buying anything:
1.) Is the distributor getting power? Surprisingly just cleaning/bending the connections to fit snug is all it needs
2.) Are 12 volts going to the starter? Be very careful with this. Will need two people and not the smartest idea someone under a car attempting to turn on.
3.) Since you said fuse box giggling makes it work. Remove fuses, clean the fuse box connections and then replace fuses and make sure to put fuse wax on them.
Hope this helps...
Old Jun 16, 2015 | 04:09 AM
chrisNY's Avatar
chrisNY
I know a sound I could work with. I wondering if it is in the seat belt system
Old Jun 16, 2015 | 06:22 AM
dembo's Avatar
dembo
Is your car still original as in does it still have the seat belt starter interlock system? If so, when it doesn't start have you pressed the button on the starter interlock override relay located under the hood, RH side of the firewall?
Nick
Old Jun 16, 2015 | 12:25 PM
chrisNY's Avatar
chrisNY
Nick
It has most of it, but the actual belts have been out for 20yrs, but it was never started in that time until I got it, this has been a ongoing issue since I got her running last month. At first 95% of the time she would start but it is getting worse every day. I tried pushing the button, but didn't have the key to on, and it didn't turn over., since I got her going it has a brand new battery charged and load tested, new distruter, mech tack drive, hei, new coil, cap and router, starts great when it turns over. I am really thinking it has to be electrical, not mechanic issue. But at this point I will try anything, if it is the interlock I have to figure out how to jump it than decide if I want to replace it or remove it, and figure out how to jump the clutch safety switch or figure out what it could be to find out what I need to make it reliable
Old Jun 16, 2015 | 02:53 PM
dembo's Avatar
dembo
Ok, that's probably not it then (ps, read here to bypass the relay http://home.comcast.net/~vettfixr/page17.htm sry IPad crashes when trying to link it.
Did you run a new wire to the HEI which has constant 12V during starting and in on position? If you use the original fused (yellow) wire the voltage will drop during starting and HEI's don't really like that.
Nick
Old Jun 16, 2015 | 03:39 PM
Peterbuilt's Avatar
Peterbuilt
This is another way to bypass the relay:
http://home.comcast.net/~vettfixr/page16.htm
Just remove the relay and install a jumper wire in the correct holes.
Old Jun 17, 2015 | 04:34 AM
chrisNY's Avatar
chrisNY
Nick
There is a new wire from the hei to the ign contact on the fuse block, I was wondering what the fused yellow wire was for, it is not connected to any thing right now, can I get rid of it? Or should it be getting power to run anything?
Old Jun 17, 2015 | 11:31 AM
Peterbuilt's Avatar
Peterbuilt
The yellow wire was only used with the points distributor, it runs from the starter solenoid to the + terminal of the original coil and only had power with the key in 'start'. Your HEI distributor does not need the yellow so just tape it off.
Is the NSS good and the linkage connected?
Old Jun 17, 2015 | 03:19 PM
dochorsepower's Avatar
dochorsepower
Sometimes this condition is the result of the starter solenoid not completing the contact circuit. If yours is an old starter or a cheap rebuild that could be a problem. Either rebuild the solenoid with quality contacts or by a quality starter assembly. This has happened to me a couple of times until I found this out. Now if I have a problem, I spend the bucks for a NEW Delco-Remy starter.
Old Jun 18, 2015 | 06:49 AM
LS4 PILOT's Avatar
LS4 PILOT
Could it be a bad spot on the starter commutator ? Every so often the rotor is positioned in this bad spot. Just sounds like something to do with starter and solenoid . I think the originals GM are better than anything new for stock motors . Pirkle guy in FL does good work. His father rebuilt mine 25 years ago , no issues.
Old Jun 18, 2015 | 09:35 AM
chrisNY's Avatar
chrisNY
Not sure yet, I will be home tomorrow and going to start trouble shooting, first I am going to jump the firewall relay. If it was a bad spot on the starter and it hasn't turned than it shouldn't start when I try it, and when it does this it does eventually start. But eliminate the easy stuff first than on to the fun stuff lol
Old Jun 18, 2015 | 11:20 AM
dembo's Avatar
dembo
Good luck Chris, can't help you any further, those two things I mentioned are the only two I've had experience with
Nick
Old Jun 20, 2015 | 08:39 AM
chrisNY's Avatar
chrisNY
jumped the firewall relay, no change, replaced all the fuses, no change, got power at the starter, and can jump the solenoid and she will turn over and catch but not stay going, no power at the alt, or distribution block. so I am thinking the solenoid is not sending power out the other side and back to the fuse box, and anywhere else at a constant. does anyone else think this could be the case??
Old Jun 22, 2015 | 02:34 AM
chrisNY's Avatar
chrisNY
Replaced starter and coil, still wouldn't start, ran a new 12V constant from the battery to distribution block and she started right up
To 74 starting issues
