Head/compression question
Old Jun 18, 2015 | 09:17 PM
rayluka's Avatar
rayluka
Default Head/compression question
If I replace my factory L-48 heads with the edelbrock 60909 64 cc heads, What will this bump my compression to. I also plan to use a thin gasket. Im gonna look at a cam and want to know what I''l have to start with.
Old Jun 18, 2015 | 09:35 PM
Jartanyon's Avatar
Jartanyon
Ultimately depends on pistons, bore, deck clearance, gasket, etc, but could get you up to 9.6:1.
Old Jun 19, 2015 | 04:41 AM
jb78L-82's Avatar
jb78L-82
If everything is a stock L48, figure roughly 9-9.2 . Stock compression L48 was advertised as 8.5 but in reality about 8-8.3...lower for an engine with miles on it.
Old Jun 19, 2015 | 10:31 AM
gg521's Avatar
gg521
The thickness of the head gasket depends upon quench distance. The optimum is around .040".
Old Jun 19, 2015 | 10:38 AM
Jartanyon's Avatar
Jartanyon
True. If you are using different heads and shoot for optimum quench with your gasket and deck clearance, then stock compressions will be irrelevant. When I rebuilt mine, my quench was .040" and my compression is right around 9.5 to 9.6:1. Just make sure to measure your deck clearance when the heads are off...they can vary.
Old Jun 19, 2015 | 03:19 PM
bluedawg's Avatar
bluedawg
9 to 1
Old Jun 19, 2015 | 05:36 PM
rayluka's Avatar
rayluka
Thanks for the info guys. So Im safe to guestimate it close to 9.5:1. I will use .040 gasket.
Old Jun 19, 2015 | 11:01 PM
bluedawg's Avatar
bluedawg
Measure the distance the piston is in the hole, .it's probably like .025" figuring you want a total of .040" you'd want a .015" compressed thickness gasket and this would get 9.2ish to one.
Old Jun 20, 2015 | 03:40 AM
rayluka's Avatar
rayluka
Do you mean from the top of the deck to piston? I think I get it. .025 plus .015 gasket is .040 total
Old Jun 20, 2015 | 03:18 PM
Jartanyon's Avatar
Jartanyon
Correct. Felpro 1094's are usually the go-to shims for .015 difference.
To Head/compression question
