Drive Line Failure?
Well I drove my 73 to work Friday morning and got ¾ there and was stopping at a red light, down shifted the th400 from 3-2-1, but when I went to take off all I got heard was a horrible grinding/banging noise. Tried to select other gears but didn’t matter, same horrible noise. So shut her down and pushed to the side of the road and waited for a tow home.
So, got the rear up on jacks this am and pulled the rear wheels. Did a visual inspection, nothing looks broken, all u-joints look intact. LR hub turns freely with trans in park, RR locked and I could not turn the hub. So I tried to start the engine, still in park, got this horrible rat-a-tat-tat sound, so backed off, moved gear selector around and back to park and then successfully started the engine without any noise. Then I put it into reverse and LR does nothing but RR spins once I took my foot off the brake. Repeated this a couple of times, did not try any forward gears.
Also, when I shut the engine off I got a little short bit of the rat-a-tat noise and then some type of whoosh sound. What the heck is that!?
So do I have a diff issue and/or trans issue or what’s my next step in diagnostics.
BTW, the trans was rebuilt around 71k and car now has around 84k miles. I sometime would have a clank sound when putting it into gear, but not always, otherwise drives and shifts smoothly. The engine looks like it’s a warranty engine replacement at some time in its past as it has a CE at beginning of the engine stamp, but for a 350 it does not seem very powerful, but I’ve never had a Vette with an automatic trans before so…
I’m thinkin I’m in for an expensive trany/diff repair bill in the near future, lol.
Any help in diagnosis would be much appreciated.
Thanks in advance,
Marc
Thanks in advance,
Marc
I had a similar noise. Look at mine
https://www.corvetteforum.com/forums...ide-yokes.html
Wow, that's some kind of torque you must have to twist it like the pix in your link shows!?
Yeah, I can spin RR freely with car in park, spins the half shaft as well so the yoke going into the diff is busted then. If I put the car in drive I get all kinds of banging, guessing that broke part is catching on something, so I'm hesitant to do that
. However, I can do it in reverse and it spins the RR okay so drive shaft is turning obviously. Not sure why the broken part is not catching reverse, must be pushing it out of the way or ?. I'm not a diff guy so it'll be a tow to a shop somewhere.
. However, I can do it in reverse and it spins the RR okay so drive shaft is turning obviously. Not sure why the broken part is not catching reverse, must be pushing it out of the way or ?. I'm not a diff guy so it'll be a tow to a shop somewhere.Mine broke due to cheap metal. That was a new part. Look for a yoke with a GM stamp on the yoke end. This is for a proper GM licensed part or GM re-tipped. The only one I was able to find with the proper GM licensed Stamp was from lonestar. Once you remove the half shaft your GM original yoke should also have the same stamp. There are other yokes that may be ok, but I wasn't about to do this repair again.
. However, I can do it in reverse and it spins the RR okay so drive shaft is turning obviously. Not sure why the broken part is not catching reverse, must be pushing it out of the way or ?. I'm not a diff guy so it'll be a tow to a shop somewhere.Wes
Thanks in advance,
Marc
From my research on the forum some have said that sound it the parking pawl in the trans. So please tell me if my next step in diagnosis make sense. Once I get the drive shaft off I'll start the engine and try the gears in the trans. I know I could get reverse to work ok after a fashion but haven't tried any forward gears.
BTW, just want to say thanks for all the information that this forum provides! What a great resource for help!
