"Oh crap"...
Old Jun 22, 2015 | 08:44 PM
labhound's Avatar
labhound
Default "Oh crap"...
Well I said more than that when this happened,
While installing the balancer, the bolt started to have more resistance, so I backed it out a bit, it resisted then broke.
I'm hoping to drill through the remaining bolt and use an extractor, more colorful vocabulary will follow i'm sure.
If there are any tips please let me know, thanks.
Old Jun 22, 2015 | 08:59 PM
toobroketoretire's Avatar
toobroketoretire
That's what happens when you don't use a damper installer to pull the damper on. All you can do is run a 1/8" bit thru the dead center of the broken bolt then a larger bit for the largest screw extractor you can use. If it still refuses to come out you can drill it out with a 7/16" bit then Heli-Coil it back to 7/16" NF.
Old Jun 22, 2015 | 09:14 PM
labhound's Avatar
labhound
I know, could'a, should'a, would'a, but it's done and all I can do now is fix it and learn.
That's what I kept telling myself as I sipped on a margarita earlier.... fix it I will.
Old Jun 22, 2015 | 11:12 PM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
Not Good.
It has been awhile since I removed a balancer and reinstalled one, but I bought the tool instead of renting it.
It cost me 30 bucks for the Lisle Brand tool.
Rule No. 1
Do it right, don't half *** anything.
Old Jun 23, 2015 | 02:01 AM
OMF's Avatar
OMF
If you can find the left hand drill bit for your pilot hole,, it might come out when the bit grabs.....
Old Jun 23, 2015 | 08:21 AM
bashcraft's Avatar
bashcraft
From the way he described it, sounds like the threads seized up. That thing is not going to come out easy.
Old Jun 23, 2015 | 09:37 AM
C3_ERROR's Avatar
C3_ERROR
I agree. You might need to pull the crank and take it too a shop. Hopefully you can get it out.
Old Jun 23, 2015 | 10:24 AM
DaveL82's Avatar
DaveL82
Take your time and try to drill it out moving up in drill bit size as you go. I go agree with trying a left hand drill as you get close to the actual size of the bolt as the thinner wall of the bolt after being hollowed out may let it relax from the thread in the crank.
I avoid extractors or easy outs unless the last resort because if one of those breaks off you can't drill them so crank has to come out.
Old Jun 23, 2015 | 12:44 PM
gungatim's Avatar
gungatim
the only positive thing I can add is that at least you've got a good area to make a pilot for the drill. get a piece of alum. or steel turned to fit inside the damper and drill a hole through that to guide your drill bit. most problems removing broken bolts is with people not able to drill a straight, perfectly centered hole in the old bolt.
and I would use an ez out myself, if it went in, it should come out. it's not like it's been rusted and seized...
Old Jun 23, 2015 | 01:00 PM
bashcraft's Avatar
bashcraft
Read his original post again. It did seize.
Old Jun 23, 2015 | 01:14 PM
jnb5101's Avatar
jnb5101
Some time ago another member posted with the same problem. He made a jig to center the drill bit on the broken bolt. Find his post, and he may sell the jig to you.
Old Jun 23, 2015 | 05:24 PM
TedH's Avatar
TedH
Even using a damper install tool, there is no guarantee you won't end up with a broken install tool in the crank.
That is exactly what happened when I installed a new damper with the engine in the car. The install tool snapped off. I had to remove the engine and put it on a stand. Took two weeks (removal/install) and all of 10 minutes to remove the remnant and clean up the crank threads. I found the install tool is VERY brittle metal and disintegrated when I put a small drill bit to it in order to drill it out for a removal tool. Ended up removing the remnants with a pair of needle nose pliers and a small regular screwdriver. I count myself lucky I did not have to fix the crank.
I bought a replacement install tool bit (came from Comp Cams but it may have been sourced from China) and used it to reinstall the damper one final time as I had to pull it (during my retro roller conversion in 2013).
I suppose I would rather snap an install tool off in the crank than the bolt. It is likely to be more stubborn/difficult than the tool.
Old Jun 23, 2015 | 06:13 PM
labhound's Avatar
labhound
That's just what I did and it worked !!! it's now out
sprayed parts cleaner in the hole to get all metal out and ran a tap down through it to clean up the threads, the balancer bolt went it with no problem.
As I was removing the bolt before it broke, I knew it wasn't bottomed out, so I started with a 1/8 bit and worked up to almost the bolt size drilling all the way through what remained and took it from there with chisel and needle nose plyers.
Now just waiting on a call from the shop that my head is ready.
Old Jun 23, 2015 | 06:15 PM
labhound's Avatar
labhound
I was shy of using an extractor cause I broke on of those off before and it wasn't good....
Old Jun 23, 2015 | 06:37 PM
BlackC3vette's Avatar
BlackC3vette
Just out of curiosity, the bolt that broke, was it the original or a new one?
Old Jun 23, 2015 | 06:40 PM
labhound's Avatar
labhound
Neither, it was a bolt being used to install the new balancer. Now I know what not to do....
Old Jun 23, 2015 | 08:07 PM
hugie82's Avatar
hugie82
How far in was the bolt when it snapped. If it's only 1/2 , try drilling it out with reverse drill bits until it backs out. Most likely the threads started to get chewed up causing the break.
If it's in more, it may be cheaper and less labor to just pull the motor and crank. The machine shop will get it straightened out and right the first time.
To "Oh crap"...
Old Jun 23, 2015 | 08:36 PM
BLUE1972's Avatar
BLUE1972
I like to use ALLEN bolt , washers hardened all with never seize to install the balancer, not an imported Allen.
I always chase the bolt and threads just incase of burs..
Old Jun 23, 2015 | 09:08 PM
labhound's Avatar
labhound
It's all good now, the broken one is out and the new is on.
Old Jun 23, 2015 | 10:17 PM
bluedawg's Avatar
bluedawg
I agree completely.
