9 Inch Ford IRS for a VETTE !
Old Aug 17, 2002 | 11:40 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Default 9 Inch Ford IRS for a VETTE !
I was looking for some more information on the Six-Link rear suspension and found this the other day, It might not be to hard to make one.Take a look at it......................JIM
http://www.dutchmanms.com/1_indep9rears.html
Old Aug 17, 2002 | 11:53 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: 9 Inch Ford IRS for a VETTE ! (PROSOUTH)
:cool: :cool:
Old Aug 18, 2002 | 01:01 AM
QuickVet's Avatar
QuickVet
Default Re: 9 Inch Ford IRS for a VETTE ! (Sharky Guam)
looks cool. i think Currie makes a ford nine inch for the vettes with coil over shocks. that is what i would like one day. :yesnod:
Old Aug 18, 2002 | 06:10 AM
Aussie71BB's Avatar
Aussie71BB
Cruising
There is a guy here in Australia making a custom Alloy Billet nine inch housing that bolts straight into your C3..... with exchange rates it probably works out real cheap if you import one from Down Under.... I will post a pic when I find it....
Old Aug 18, 2002 | 06:50 AM
mrvette's Avatar
mrvette
Well it certainly LOOKS cool, but one question...can it hold a set of sticky Mickey's and a BB in the quarter???.....if so, how many times????
bet the 1/2 shafts are not much if any stronger than stock, so untill the unit passes some good stiff tests in that area, well, I'd have to pass....
we all know the weakest link by FAR, in a stock setup, is the 1/2 shafts for a variety of reasons.....
GENE
Old Aug 18, 2002 | 02:39 PM
GDaina's Avatar
GDaina
The stock set up hold up well. They break when you do the crazy godzilla power shifts and dump the clutch at the same time, but reasonable shifts, not talking about granny shifts, hold up just fine. Running all stock stuff, and plan on running stock stuff. Years ago competed in club events at Nelson Ledges, Watkins Glen, Mid Ohio, never broke anything except glass.
Old Aug 18, 2002 | 02:51 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: 9 Inch Ford IRS for a VETTE ! (GDaina)
I like the inboard discs and all, but it raises some good questions.
1. It's still the same design as he Vette, no better. Doesn't have upper control arms and uses the half shafts as control arms, just as the C3.
2. How do you put a sway bar on it?
3. It mounts quite a bit differently on the top and front of the carrier -- some custom brackets needed, at the least. I wouldn't give up that monster aluminum mount in my 1980 for that mounting solution -- ever.
4. Rod ends suck for street use. They get ruined by water and small amounts of gravel and other junk. They just get torn up, hence why they are not used on street vehicles.
I think this would be good for custom cars, as it's intended purpose. And if I ever build that Cobra / custom autocross car that I want to build, I've now found my rear end housing !!
Pretty cool.
Old Aug 18, 2002 | 04:44 PM
groovyjay's Avatar
groovyjay
Thanks for the info, this is something I still need to do oneday! :cheers:
Old Aug 18, 2002 | 04:48 PM
JRD77VET's Avatar
JRD77VET
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
Nice looking unit. :cool:
But the price :eek: $3995 for the base kit? I'd rather spend the money on a big block :yesnod:
:seeya
Old Aug 18, 2002 | 08:44 PM
PROSOUTH's Avatar
PROSOUTH
St. Jude Donor '05
Aussie71BB There is a guy here in Australia making a custom Alloy Billet nine inch housing that bolts straight into your C3..... with exchange rates it probably works out real cheap if you import one from Down Under.... I will post a pic when I find it....
_______
Yes ! This is what I’m looking for !
BSEERY
Bryan the reason I posted this was not to say “This is what I want and it’s an engineering marvel.” I merely wanted to point out that it is a viable option to entertain putting a 9” Ford chunk in a C-3 Vette center. The only piece I see that appealed to me was the fact that there was a Heavy Duty 9” pumpkin in the middle of it and that it was possible to do an IRS with it.
I would still want to utilize the 6 Link we have all been working on and I would also want to retain my C-3 Offset T-Arms and Swaybar ect. The only thing I am wishing for is a Batwing mount similar to the one in my ’80 that I could screw in a 9” FORD Chunk !
If Aussie71BB finds a housing that mounts like the ’63 – ’79 I might revert to the old style crossmember to get one.
Think about it……………………..give me chills!!!!! JIM
PS go to this web-site http://www.progressiveautomotive.com/rearends.htm and look at the front mount and the Batwing on the Dana36 street rod. I think we could use this set up to put a Dana 36 in a C-3 and still use the C-3 T-Arms. But use the ‘90s Batwing and struts instead of our 6 link. JIM
:smash: :yesnod: :lol:
Old Aug 19, 2002 | 03:36 AM
Gleese79's Avatar
Gleese79
Default Re: 9 Inch Ford IRS for a VETTE ! (Aussie71BB)
Aussie71BB: Can you forward me the details?
sounds like a good option when i destroy my diff sooner or later.
:cheers: Chris
Old Aug 19, 2002 | 08:16 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: 9 Inch Ford IRS for a VETTE ! (Gleese79)
Aussie71BB you have your work cut out for you ;)
we want pics :D
Old Aug 19, 2002 | 12:10 PM
flood's Avatar
flood
Default Re: 9 Inch Ford IRS for a VETTE ! (Twinnie)
Also notice the inboard brakes? Lotus style baby.. That is a sweet setup ! :cheers:
Old Aug 20, 2002 | 10:52 PM
JoeC427's Avatar
JoeC427
Any luck with that rear end info? Im anxious to see or hear more about that 9".
Thanks,
:chevy
Old Aug 20, 2002 | 11:50 PM
PROSOUTH's Avatar
PROSOUTH
St. Jude Donor '05
Default Re: 9 Inch Ford IRS for a VETTE ! (tiresmokin75-427)
OK, here's what Ive found. It may be a little pricey but....................
http://www.markwilliams.com
9" Ford Aluminum Modular Center
$650.00
SKU: 90100
I have a catalog from Mark Williams and it is High Tech all of the way.
The Modular 9" Ford Center includes all of the studs nuts and ashers for the end bells and center section. You would need the Bearing `Flange Axel End Bells and a set of axels.
Then there is a 12 bolt setup for all of the die hard GM guys
12 Bolt Aluminum Modular Center
$785.00
SKU: 90200.
Maybe it is all a dream.......................... JIM :sleep:
To 9 Inch Ford IRS for a VETTE !
