Pulling head
Old Jun 23, 2015 | 07:16 AM
white owl's Avatar
white owl
Cruising
Default Pulling head
Tonight I am going to start the process of pulling my driver side head due to sheared exhaust manifold bolt. I'm not sure what kind of lifters are in the motor so just wondering if I should be worried about the reinstall and setting up the rocker arm lash. Any tips or pointers would be great. Thanks
Old Jun 23, 2015 | 08:20 AM
jnb5101's Avatar
jnb5101
Number the lifters and push rods. They must be replaced exactly to match the cam. The lifters can probably be left in the engine if care is taken to keep them clean.
Old Jun 23, 2015 | 08:25 AM
white owl's Avatar
white owl
Cruising
Should I be leaving the rocker arms on and just unbolt the head and pull it or do I need to remove all the rockers
Old Jun 23, 2015 | 08:47 AM
jnb5101's Avatar
jnb5101
"As long as I'm in there"! You can leave the rockers on the head, but depending on the age and condition of the motor there are a lot of options here. Pull both heads and have them rebuilt, change the cam, change the heads, pull the whole motor and go for broke! I guarantee in six months you'll be doing a frame-off restoration!
Old Jun 23, 2015 | 08:52 AM
white owl's Avatar
white owl
Cruising
Motor is about 8 years old. It was bought new from gm it's a 355h.o. so I do not think it need completely overhauled. Also It is killing me not getting to drive it!
Old Jun 23, 2015 | 09:07 AM
530planeman's Avatar
530planeman
No need to pull lifters out .after you pull intake lay a clean rag in valley and set push rods across against other head ,most likely they are hyd. when you put things back together it take a little more time to set up lifters before you start up engine .
Shure there is no way to get to broken bolt without removing head ?
Wes
Old Jun 23, 2015 | 11:28 AM
white owl's Avatar
white owl
Cruising
Wes
Yea the bolt location is driver side in the center of the head the problem is I can not get even a close quarters drill in to drill it out due to the steering box. I'm under the impression that when I reinstall the rockers I need to start at number 1 TDC take the play out of the push rod then tighten another half turn. Correct?
Old Jun 23, 2015 | 11:33 AM
white owl's Avatar
white owl
Cruising
I would love to not have to pull the head but I have exhausted all my options on getting the bolt out. Any suggestions
Old Jun 23, 2015 | 11:45 AM
hugie82's Avatar
hugie82
If the bolt broke almost flush with the head. You can lay a nut over the broken bolt and fill it with a mig welder. Usually the broken bolt will spin right out after that kinda heat gets put to it.
YouTube has a few videos on how to do it. You may need to remove the steering shaft for welder access.
Old Jun 23, 2015 | 12:12 PM
530planeman
There are 3 (3/8 ) bolts holding steering box in if you take nuts off then the box should drop down .Giving you more room .Also if you drill small hole in center of part of head of broken bolt and use it as a guide to drill down about 1/2 " into broken part in block then use an easy out many times broken part will back out easy .as far as adjusting lifters look about how far nuts are now and I take plugs out and spin engine as I turn nuts down so oil can get in push rod up tp lifter .
Wes
Old Jun 23, 2015 | 11:22 PM
TimAT's Avatar
TimAT
IF you can get the manifold away from the head far enough to get a sawzall type blade in there just cut the bolt between the manifold and the head. Cut it off and let the machine shop drill it out.
To Pulling head
