Looking for a T-10 rear bushing removal tool
Looking for a T-10 4 speed rear bushing removal tool for my 75 Vette. It is for removing the brass yoke bushing in the tail end of the tranny while the tranny is still in the car. I called Kent-Moore and they don't have a tool listing that goes that far back.
I looked on Ebay and couldn't find anything. So if someone has one to sell or rent please let me know.
Thanks.
Thanks.
The pullers I have will not work with the 32 spline 1 7/8 yoke.There are 2 more Snap On pullers S8687A and S 9611. I do not know the diameter of either one. S9611 is for GM 400 and that is 32 spline in link below. I do not know if it will work for you.
http://www.collectingsnapon.com/cata...talogPage=3028
I will see what I can come up with.
Didn't know it would be this hard to find the tool.
http://www.skspeed.com/manual-transmission-shop.aspx Call the tranny shop and ask for Brian (If he is still there, he was looking to sell and retire)
So if anyone has any leads on a tool Please PM me here.
They couldn't have all fell of the face of the earth ??
Still looking.
Looking for a Super T10 BW 4 speed transmission tailshaft bushing removal tool to buy or rent. It's for the 32 teeth output shaft.
I have looked every where, Ebay, tool companies , Etc. It seems they all disappeared of the face of the earth. Kent Moore tool company doesn't make them anymore.
So if anyone has one or knows someone that has one PLEASE let me know if I can buy or rent it.
Thanks!
Thanks!
Have you thought about just removing the tail shaft? I know its a bit more work but probably can be done in a few hours instead of trying to track down a tool.....
Also, why are you trying to change it? Is your tranny leaking from the slip yolk?
Yoke and busing are worn.
I also couldn't find the tool for my 74 4speed. I took a hacksaw blade and ground it down so it would fit in the tail housing. The tail shaft splines held the blade in the proper position and it wasn't too bad sawing by hand. Took about 30 minutes. I then used a various makeshift tools and was able to hook the front of the bushing and slide it out.
Daniel
I currently have a Snap On S8687A that I borrowed, but it's just a *hair* too large in diameter to catch the rear edge of my bushing. My yoke diameter is 1.5" and the new bushing ID is 1.502" (from what I can tell). So, the tail shaft diameter should be 1.630" (I believe).
Daniel
Nestor-
Daniel
Daniel
Nestor-
I understand the dimension you're after now. The diameter of the "output shaft," which is the splined (27) end of the main shaft, is 1" (I'm 99% sure). I can verify the measurement this evening.
The ID of the bushing I'm trying to remove is 1.5." From your second photo, it looks to be the correct tool.
Daniel
Daniel
