79 L82 vacuum testing
Old Jun 25, 2015 | 03:34 PM
Billyo's Avatar
Billyo
3rd Gear
Default 79 L82 vacuum testing
Looking for someone to explain what's going on at vacuum selector switch. Mine has five hook ups in back of it. Plug is missing. I have black,green,white, and blue. Vacuum comes in on black. If you select air condition should there be vacuum on which hose and runs to where. And same for heat and defrost. I'm having trouble getting center vent to work. Heat and defrost not a problem. Thanks
Old Jun 25, 2015 | 03:40 PM
MelWff's Avatar
MelWff
this diagram from Willcox has the vacuum line routing
http://repairs.willcoxcorvette.com/w...-schematic.pdf
Old Jun 25, 2015 | 03:43 PM
speedreed8's Avatar
speedreed8
probably needs a new v. switch
http://www.zip-corvette.com/catalog/...category/7337/
Old Jun 25, 2015 | 04:12 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The numbered connecter in the Willcox diagram is part of the HVAC vacuum harness. You say you have a "plug" missing. Are you missing this connector?
To 79 L82 vacuum testing
