Any spark plug suggestions?
Old Jun 27, 2015 | 01:46 AM
74BlueBeauty's Avatar
74BlueBeauty
Cruising
Default Any spark plug suggestions?
Hey guys,
Bought a '74 from an old man wanting to retire. Its got a 350 Crate engine thats about 7 years old or so. Old man claims to have put about 5,000 miles on it or so.
Anyway, I was wanting to change the spark plugs as I already changed the oil + filter and radiator fluid.
Any suggestions?
Thanks,
E
Old Jun 27, 2015 | 06:25 AM
mikep3's Avatar
mikep3
I am an old man and retired!
The first step in selecting spark plugs is to know what heads you have.
The "word" crate engine tells us little, maybe a picture or builder and part number.
Also what ignition or distributor you have? 74 had an electronic per HEI and most crate come with HEI.
Old Jun 27, 2015 | 09:47 AM
74BlueBeauty
Cruising
sorry! Its just that im a young guy!
No clue what part number or exactly what engine it is really. I really want to find out. Heres a couple pics.
Old Jun 27, 2015 | 10:05 AM
terry82's Avatar
terry82
take out the old plugs and see what number they are. on my 82 I take out the two in the front on both sides from the top . the back two from the bottom.
Old Jun 27, 2015 | 10:32 AM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
I'm running NGK's on mine currently, mostly because that is what the Engine Builder suggested.
Davis Unified suggests Autolite Platinum with their distributors, gapped to .55 I think.
For you, run of the mill AC Delco's should be fine.
Old Jun 27, 2015 | 12:43 PM
mikep3's Avatar
mikep3
Just guessing but that looks like a 73 or 74 with points distributor. I would pull several plugs and see what kind they are and thier gap. Points distributor SBC use AC DELCO R45TS gapped at .035? Then you go off the deep end with brand names like Boch or Champion, bla blah.
Old Jun 27, 2015 | 08:07 PM
Sayfoo's Avatar
Sayfoo
I have found that with modern gas, even the cheapo $.99 plugs work for a lot longer than 5k miles . Back in the day, the standard was to change the points and plugs at 10k miles. Points wore out and the leaded gas ate the plugs. Not so now. I pulled a set at about 9k miles on my '69, and they looked practically new. I put them back in and the car still runs well 7k miles later.
So, pull the plugs and if they look ok--no heavy deposits, worn tips, etc.-- put them back in.
99% of the time, changing to a particular brand or a so called "high performance" plug will not do anything. You are just wasting your money.
FYI The only plugs that I have ever had a problem with was Champion. I found bad ones on 2 separate occasions, so I won't buy them, but any name brand should be ok.
Old Jun 27, 2015 | 09:22 PM
ctuinstra's Avatar
ctuinstra
I've always been an NGK fan. They have never let me down. No reason for any special, fancy plugs!
Old Jun 27, 2015 | 09:48 PM
73L82AIR's Avatar
73L82AIR
Lots of old men on here
To Any spark plug suggestions?
