turn signal problem 1977
Old Jul 11, 2015 | 11:27 AM
jgcable's Avatar
jgcable
Default turn signal problem 1977
Turn signals will work whether the ignition is on or off. The only difference is they are very dim when the key is off. What should i look for?
Old Jul 11, 2015 | 12:10 PM
Gazehound's Avatar
Gazehound
I had the same problem on my 77. It turn out to that I install the parking/turn signal bulb backwards in the socket. On one side of the bulb both filaments are tied together to provide ground and when you have that in backwards you tie the turn signal and parking light signals together causing your condition. Hope this helps!
Old Jul 11, 2015 | 01:16 PM
jgcable's Avatar
jgcable
When i unplug the connectors to relay # 3989214 my turn signals go back to normal. Wtf???
To turn signal problem 1977
