Speedmaster79 Parts
http://store.speedmaster79.com/c-193...=2-101-482-24-
Basically you have to except anything from a place like that can be junk form go or that you might have to finish/fix it yourself. And I'd expect the same junk replacement parts or the run-around if you do have a problem. To me it's just not worth the wasted time if something goes wrong. I have hard enough time with good brands quality, but they usually are a lot better to deal with when something is bad. It really sucks to have a part hold you up or have to figure out a compromise to get you by.
So thoughts....results?
The other alternative is to stick with Vortec heads and use Howard Roller Cam / Roller Lifter combo with my Q-jet and I can still keep it under $2000. Howard Cam has the lowest price on cam / retro-roller combo. My target is 400hp.
Heads - GMPP Vortec 12558060 $600.00
Cam/Lifters - Howards Cams CL110245 $500.00
--Duration @ 050: 234-238 Lift: 0.539-0.548
Intake - Edelbrock Performer Vortec 2116 $180.00
Carburetor: Stock Q-Jet - -
COMP Cams 1.5:1 Aluminum Roller Rocker Arms 1015-8 $175.00
GM Performance LS6 Springs 12499224 $68.00
Comp Cam Magnum Pushrods 7.8" CCA-7372-16 $100.00
ARP Head bolts ARP 134-3601 $77.00
ARP Intake bolts ARP 134-2002 $18.00
Cloyes Gear Timing Cover 9-221 $116.00
