Air Conditioner Disconnect
Old Jul 12, 2015 | 11:11 AM
Brother Rob's Avatar
Brother Rob
Default Air Conditioner Disconnect
My 73 came with heater bypassed and Air Conditioning not working. When I move the dials and blower speed, nothing happens. I'm assuming the heater core is no good. And I'm fine without heat. By the time I need heat, it will be time to put her away for the Winter.
While it might be nice to have Air, I'm ok with just keeping the T-Tops off and roasting my toes.
The compressor is original and apppears ok. So I'm inclined to let it stay where it is. But the belt is still connected.
Is there any reason not to just remove the AC belt? I assume I'd lower the load on the engine a bit. Or should I just leave the belt on?
Old Jul 12, 2015 | 11:17 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Brother Rob
...Is there any reason not to just remove the AC belt?...
No, if that's what you want to do.
Old Jul 12, 2015 | 11:18 AM
Brother Rob
Cool. Thanks man.
To Air Conditioner Disconnect
