LS wiring on my 71
As I've done other LS swaps I ran a 4 gauge wire from the starter stud to the stud on the alternator. Original wiring on the 71 brought the power wire from the starter stud around and to the horn relay. I deleted this wire and ran a 8 gauge wire from the alternator stud to the horn relay. In the process I deleted the fusible link.
So without the fusible link thought I should add a Maxi fuse in-line on the wire from the alternator wire to the horn relay to protect the car. What size fuse? I bought a 40 amp. Too big? Too small? I don't have any large amp draws. No air or large stereo systems.
You don't have any large amp draws but a dead short is a whole different story.
