I will post all my photos when I'm done. I have installed my stroker with the 700R4 and everything fits perfect. Drive shaft was shortened 3" and the parking brake cable pulley was moved 3/4" to the left. It's all in an looks factory. I have the shifter detent kit to install.
My question here is what to do with the shift cable mount bracket as it doesn't match up to the pan bolts?
Do I just need to cut the bracket and weld in a lengthened piece?
Or can I use a bracket from the C4 or maybe 4th gen Camaro?
Thank you all. My head is out in the open now and yes I do have the bracket in my kit.
Thanks to past information on the forum my 700 install went together and looks like factory. I will post photos of my entire build as soon as its done. Couple more weeks.
Also thanks to a member for supplying the modified "tung mout" as I call it.
Information here took a lot if guess work out. Very straight forward.
