TH400 swap
Old Jul 16, 2015 | 03:56 PM
caryb78's Avatar
caryb78
Default TH400 swap
1978 pace car, L-82some upgrades to engine. What if any are the advantages or improvements in installing a TH400. How hard is the swap and what will be gained?
Old Jul 16, 2015 | 04:00 PM
JimLentz's Avatar
JimLentz
Why not just install an overdrive transmission? A TH-350 can be made to handle a fair amount of torque.
Old Jul 16, 2015 | 04:35 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Turbo 400 requires a electrical signal to control the Kickdown shift. Instead of a mechanical linkage.
for proper operation of T400 you will need a (switch / wide open throttle position),
to control passing gear kickdown.
Old Jul 16, 2015 | 04:42 PM
toobroketoretire's Avatar
toobroketoretire
The TH400 was used in all of the high horsepower small blocks and big blocks because of it's higher torque rating. If you presently have a TH350 and put a lot of miles on it I'd strongly recommend changing over to a TH700R4 for it's 30% overdrive 4th gear. The TH700R4 can easily be built to handle 500+ ft/lbs of torque so it makes a great big block transmission.
Old Jul 16, 2015 | 04:58 PM
lurch59's Avatar
lurch59
I had a T400 in my '56 chevy with no electrical signal and the kickdown worked. Could be that it was an older trans....
Old Jul 16, 2015 | 05:25 PM
mrvette's Avatar
mrvette
My '72 has a 336 rear ratio, and so first glance some 18 years ago it was the 700, but in driving it, the car got maybe 1/2 way across in intersection, upshifted and bogged the engine, and I had FI on it even then......
the solution was a 200 4r no violent drop from 1st to 2nd.....smoother and still the same ~.70 overdrive....knocks 4000 rpm at 80 mph down to 2500 or so.....
AND you don't need to modify cross supports, driveshafts, etc.....
Old Jul 16, 2015 | 05:43 PM
augiedoggy's Avatar
augiedoggy
hmm... there was no such switch on my 74 when I bought it? unless its installed behind the pedal somewhere? someone swapped the carb with an edelbrock right before I bought it.
Old Jul 16, 2015 | 06:22 PM
TimAT's Avatar
TimAT
augie-- the 400 detent switch is mounted on the pedal pivot -- above the pedal so the upper half of the pedal hits it.
To TH400 swap
