Trailing arm bushings
Old Jul 17, 2015 | 01:02 AM
Strokemyaxe's Avatar
Strokemyaxe
Default Trailing arm bushings
How can I tell if they need to be replaced?
Old Jul 17, 2015 | 08:13 AM
vbgod1's Avatar
vbgod1
Well, on mine.....
It was on a frame lift, I put a long screwdriver up there and could see it move. Got my big Channellocks, grabbed it and the bolt and bushing were solid, but the arm rocked back and forth. I was looking for something, because it looked like the tire was rubbing the frame, I somehow broke a camber rod in my first 100 miles, and the PO had broken the other right before I bought the car.
Old Jul 17, 2015 | 08:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Strokemyaxe
...hiw can I tell if they need to be replaced?...
Are you having alignment issues not related to strut rod bushings?
Old Jul 17, 2015 | 11:35 AM
Strokemyaxe
Well, I'm replacing the oe struts (bent right side) with new adjustables. I already have the rear end broken down for that job. I noticed my trailing arm (without struts, spring and shock connected) is able to twist in place a bit. Didn't know if this was normal or if it meant the bushings were needing to be replaced.
I don't believe mine move left to right... Just twists in place. I'll double check on horizontal movement tonight.
Old Jul 17, 2015 | 11:48 AM
76Rat's Avatar
76Rat
That is normal as long as they don't move up/down or front/rear
Old Jul 17, 2015 | 12:44 PM
Strokemyaxe
Oh, good news then! They definitely don't move up or down. Very solid in that regard.
Thanks!
Old Jul 21, 2015 | 06:30 PM
Strokemyaxe
Well, it turns out the only the left side was good (the only one I checked up to this point). Have new bushings on their way....
Thanks again.
To Trailing arm bushings
