I'm building a 383 stroker, roller cam and vortex heads for my 1978 C3 and I'm having clearance issues with my water pump pulley. I'm using a Speedway Products short water pump and a set of Aluminum CVF racing Corvette Pulleys. The water pump pulley is rubbing on the pump. I've ordered a set of shims from Summit but was wondering if anyone else has had this problem? I can't even check alignment until I can get the pulley to bolt up flush.
Any help will be greatly appreciated.
Rboz57
If you're not putting the water pump pulley straight on it WILL hit the crankshaft pulley and even bind up on it. Try installing it again and make sure its going on dead straight.
Shimming ever so slightly will probably fix it. I have a Stewart Stage 2 pump and had a similar issue. I ended up grinding the water pump housing a small amount to clear it. Another not so good option (that I have done before) is to file or grind the back of the pulley. My .02.
I have had similar issues and had to shim the pulley. I think the corvette pumps are actually slightly different than a standard short pump...so the corvette pulley with a short pump could be your issue. I don't remember where i read that fwiw
Thanks, I'll try shimming first. I may still need to grind the water pump slightly. How much clearance do you think I need?
It clears the crankshaft pulley with no problem, it does hit the water pump housing before sitting flush. Once I shim it and bolt it down, I'll be able to check alignment. I'm going with electric fans so if I need to shim the dampener on the crank, I can do that too. I'll post a photo after I get the shims installed. Thanks.
Long Chevy Pump = 5/8" pilot diameter & 6-15/16" block to hub distance
Short Chevy Pump = 5/8" pilot diameter & 5-5/8" block to hub distance
Corvette Pump = 3/4" pilot diameter & 5-13/16" block to hub distance
So a 3/16" spacer will put your pulley back where it should be. So long as the crank pulley's are still original, or if they are new, that they are in the original position, then you should get true belt alignment.
The pilot stub will be smaller though, and this helps ensure the pulley is central on the pump. If you have an aftermarket pulley, then the pilot hole will probably be the smaller 5/8" size. The original Corvette pulley will have a larger hole than the pilot.
You can also get aftermarket pumps (including aluminium ones) with the original Corvette specific dimensions.
Start with the smallest shim in the kit that you ordered. Increase in thickness until you clear the pump. Make sure that your pulleys are aligned after shimming. If shimming throws the pulley alignment off too much you will have to resort to one of the other methods.
I knew i read that somewhere...just couldn't remember the details.
OP...just get a pulley for a regular swp. It should fix your problem. I an running that setup with no problems. PS pulley should bee close enough that it won't be a problem...i should mention that i an also using a swp alt bracket.
Just to clarify, Corvette Pump = 3/4" pilot is for '71 and up pumps.
'70 and older use 5/8" pilot pumps.
In '71 the pump bearing size was increased.
Thanks Barry's70LT1
The 3/16 spacer put the pulley in the correct alignment. Went together with no problems. Thanks everyone for your comments!
Rboz
