Headlight/wiper vacuum
Here's the deal.... I've been working all summer on finding and fixing my vacuum leaks. My system will currently hold vacuum for several hours. I still have a small leak somewhere on the command (small hose) side of the system. The leak is so small it's making it a little difficult to track down. The car will often sit for a week or more between starting the engine. After sitting for that long the vacuum system has lost pressure so when I start the car the LH headlight pops open along with the wiper door for a couple seconds until vacuum pressure has been reestablished, which drives me nuts. I was at a recent car show and asked these questions to other C3 owners and they all said they would be thrilled if their systems worked as well as mine.
New C3's would easily hold vacuum for several months but over time the spool seals in the relay valves and wiper park valve begin leaking and then the vacuum can be lost within a 24 hour period. Of the valves I would rate the wiper park valve as the most common problem.
When you park the car in the garage with the headlight & wiper door in the closed postion, vacuum will eventually leak away (the vacuum tank actually fills with atmospheric air). When you start the car it starts to create vacuum, if the headlight & wiper door pop up for a second it means that the control valve to that system is compromised and is allowing muscle vacuum to the wrong side of the valve.
I also want to know if after the system has been compromised if a door opening on start-up is common until vacuum has been reestablished.
Another possible cause is if there is any vacuum loss around any of the rubber pistons inside the relays, thus not being able to direct actuating vacuum to the proper port. This is VERY common.
Having worked on UHV (Ultra High Vacuum) systems in a previous life, and considering the complexity of the Corvette vacuum system paired with the usage of many not-so-leak-proof parts (even when new), this sounds incredibly long... 'An hour or so' would have been my guess...
The control side (large hoses) of my vacuum system is sealed and will hold vacuum for several days or longer. All of my valves, check valves, and actuators are new and have been tested. For the record two relays were bad when they arrived. One had a broken center vacuum port, the other was internal and the red port would not open.
The basic problem is I have a small leak on the command side (small hoses). The leak is so small it takes an hour for the leak to register on a vacuum gauge, which makes troubleshooting a long and time consuming affair.
And I know my leak is not in the wiper safety (park) valve as I isolated that section of the system and it holds vacuum. I've started isolating sections of my system and working backwards, sooner or later I'll find the section causing the issue, but working under a C3 dash is not the most comfortable place to hang out. And again I was just looking for answers to the two questions asked in the first paragraph.
Have you checked the headlight vacuum valve? This is probably the poorest design in the entire vacuum system. You do not have to take the dash apart to check it. By being creative, it's simple to check.
Block the hose leading to the right side of the wiper door solenoid, pinch closed the control hose leading to the relays, and connect the vacuum pump to the small hose at the check valve. You can now pump up just the headlight vacuum valve and test for leak down.
