hei coil
Old Aug 19, 2002 | 08:26 PM
terry82's Avatar
terry82
Default hei coil
can a hei coil go bad slowly or do they just go out?trying to figure out if the coil is bad or the modual in the distibuter is bad .
Old Aug 19, 2002 | 08:49 PM
QuickVet's Avatar
QuickVet
Default Re: hei coil (terry82)
who made the distributor?
i think the coil can slowly go bad. i had be advised to change mine even tho the car still ran. tho it wasnt running that great.
[Modified by QuickVet, 7:50 PM 8/19/2002]
Old Aug 19, 2002 | 09:57 PM
Jvette73's Avatar
Jvette73
Default Re: hei coil (QuickVet)
Ive had many a modules go bad...never had a bad coil...just my expierence.
Old Aug 20, 2002 | 03:02 AM
glen242's Avatar
glen242
I had a year old "performance" coil go bad all at once. Found a crack in it. No indication of a problem until it stopped working. Went home on a flat bed.
Old Aug 20, 2002 | 04:33 AM
riorata's Avatar
riorata
I have had several "coil n cap" coils go bad. Just cruising along at 3500 RPM or so, then backfire through carb and dead coil. I believe they overheat and open up dramatically. Very frustrating. I always carry a spare.
I intend to rectify my aftermarket MSD HEI distridutor situation as soon as I get back to the states.
:cheers:
From Bahrain
Desert Rat (for now) :flag
Old Aug 20, 2002 | 04:47 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: hei coil (riorata)
I've seen this happen too..but a stand alone coil...Nope!!!!!
P.S. Hi Desert Rat :cheers:
Old Aug 20, 2002 | 07:36 AM
Gary79's Avatar
Gary79
Default Re: hei coil (Desertdawg)
i just went thru a frustrating experience with this. my vette would start sometimes and sometimes not. I have a rebuilt distributor from Accel, 2 yrs old, and i took the ignition module to Autozone to test it, they ran it for about 5 minutes, no problem. so i test the pickup coil, and the pink wire to the distributor and everything is fine. the ignition coil itself was giving various readings, so i took it to another parts place and they tested it several times and thought it was not good. so i bought a new one,$30, went home,put everything back together and NO GO !!. in frustration i dug the old distributor out of the attic and wiped off the GM ignition module,put some dielectric grease on the bottom of it, installed it and VROOM!! runs like a top, that was last Thursday evening,drove it all weekend, no problems. So I'm going to run the 24 yr old ignition module with the GM logo on it til it drops.
To hei coil
