carter electric fuel pump
Old Jul 20, 2015 | 10:29 PM
nova454ss's Avatar
nova454ss
Navigator
Default carter electric fuel pump
Is anyone running carter electric fuel pump and if so how do they preform I order p4600hp 100gph 6-8psi to run behind a 454 with no regulator or return line. I was told if i run a return regulator it will last longer and I was also told it would lose psi. what kind of psi do you have? I think i should have just have just went with the 15-19psi version and ran a return regulator.
Old Jul 20, 2015 | 10:55 PM
74modified's Avatar
74modified
To really run a good quality fuel system, you need a regulator/return. The regulator cuts the pressure at the point it is set for and returns the "extra" fuel to the tank. If you have a pump that puts out 100 gal per hour, and you are using 5 gal per hour - guess what happens. The pump is basically deadheaded and heats the fuel. The hot fuel is not good for the pump or your engine.
Old Jul 21, 2015 | 12:32 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
No need to go with electric fuel pump, I have been using the same Carter Street Super Fuel Pump for many years on 400 - 600+hp engines in my Corvette. They flow 120gph and good for 600HP @ 7000 RPM
Old Jul 21, 2015 | 12:59 PM
nova454ss's Avatar
nova454ss
Navigator
I have a gen 6 bbc crate engine it has the fuel pump boss with block off plate. i dont know if it has the lope for the fuel pump
Old Jul 21, 2015 | 01:42 PM
hugie82's Avatar
hugie82
What year vette you running? The 82 corvette has the 15psi pump and a return line. You just plumb the carb and regulator.
Old Jul 21, 2015 | 03:20 PM
nova454ss's Avatar
nova454ss
Navigator
73 corvette I went ahead and order p4601hp pump 9-15psi 100gph and holley bypass regulator. I read a few people could only get 5psi from the 4600 pump and i didnt want to under fuel the holley.
i did order a cheap summit fuel filter. i have holley inline filter and cheap clear filter to see that its getting fuel. I was thinking put the summit filter first, pump, holley filter and then the regulator. Im thinking i might ditch the clear filter.
I also order a vod fuel gauge that is not fluid filled.
Old Jul 21, 2015 | 07:46 PM
Iceaxe's Avatar
Iceaxe
I'm running a Carter electric fuel pump and it works perfectly on a 1970 Corvette L-46.
I believe this is the pump I'm running:
http://www.summitracing.com/parts/crt-p4070
The Carter fuel pump was on the car when I bought it, originally I was going to replace it with a stock setup, but the system is trouble free and the car starts instantly, even after setting for 6 months in storage, so now I've decided why mess with a good thing. The electric fuel pump is staying.
FWIW: when you turn the key to the ON position you hear a mild hum, once the engine fires the sound is no longer noticeable. I only mention this because some don't like the hum of an electric fuel pump. Personally I find it comforting in that I know the engine is getting fuel.
Old Jul 21, 2015 | 08:27 PM
wilcar's Avatar
wilcar
Carter 4070 also on my 455 Gto and 460 Ranchero with no problems for 10 years.
Old Jul 21, 2015 | 09:02 PM
nova454ss's Avatar
nova454ss
Navigator
i agree the electric fuel sound doesnt bug me at all. I have headers with 3" 40 series flowmasters.
Old Jul 21, 2015 | 09:14 PM
7t9l82's Avatar
7t9l82
Electric pumps have their good points, I never had a problem with one.I run a mechanical pump now.
To carter electric fuel pump
