C6 15 spoke wheels on c3
Old Jul 21, 2015 | 01:11 PM
75myway's Avatar
75myway
Default C6 15 spoke wheels on c3
I'm thinking of picking up a set of the c6 15 spoke wheels for my 75. I believe these are the same size as the c6 5 spoke I see people use on here. Any opinions? I think they are a good deal at $550 for just the wheels...Thanks all.
Kurt
Old Jul 21, 2015 | 01:35 PM
augiedoggy's Avatar
augiedoggy
since the offset is all wrong your would need some serious spacers to make them work no? and how wide are they? most have issues running anything over 8" wide without modifying the suspension.
Old Jul 21, 2015 | 01:47 PM
75myway's Avatar
75myway
Fronts are 18X9.5 and rears are 19X10. I think they are the same size as the c6 5 spoke. I am hoping they will use the same backspacing 3" in the rear and 2.75" up front...
Old Jul 21, 2015 | 01:54 PM
MelWff's Avatar
MelWff
what modifications are you making to be able to use these wheels?
Old Jul 21, 2015 | 02:00 PM
75myway's Avatar
75myway
I have offset trailing arms and plan on getting wheel spacers. Will these work with those mods?
Old Jul 21, 2015 | 02:31 PM
Duane4238's Avatar
Duane4238
If it's the look you're after, You might want to think twice. I have wheels that look just like those on my Civic Special Edition. They are a TOTAL PAIN IN THE A** to keep clean. I would never go that route again. Look for something with far fewer spokes.
Duane
Old Jul 21, 2015 | 11:39 PM
76CSRvette's Avatar
76CSRvette
I used 2.75 and 3.25 I could have made the front a little bigger but i wanted them in 1/4 but 2.90 would make it more flush to the fender. The C7 wheels are also the same sizes and offsets i believe and soon i will probably change to those in the near future.
this thread is the holy grail of c6 rims on c3's. I had bought the rims and was having trouble deciding which size adapters to use and they were going to be nonreturnable as they were custom made and wheel and hub centric.
https://www.corvetteforum.com/forums...ter-specs.html
Old Jul 22, 2015 | 06:54 AM
Ibanez540r's Avatar
Ibanez540r
That's now the go-to thread.
However, double check your front wheel measurements. Pretty sure the C6 5 spoke are 8.5" front, not 9.5" like you spec'd for yours. If true, you may have to adjust accordingly.
To C6 15 spoke wheels on c3
