Burning rubber
Old Jul 22, 2015 | 10:07 PM
1BADD78's Avatar
1BADD78
Cruising
Originally Posted by REELAV8R
This is what I found on that cam.
http://usaperform.com/street-fighter...ift-p-497.html
That's an old school grind. Low intensity ramps on those lobes. This means that the valves are open longer but not in a useful way.
Your over lap (time both intake and exhaust valves are open) is 71*. This is probably pared with a late intake closing. All boils down to less torque off idle but higher RPM capability.
The valve lift is normal for a flat tappet, but low compared to a roller cam. You will make power but it's gonna be later on. Maybe 2500-3000 +RPM range. A stall converter would definitely help here. Your stock 1800ish stall converter makes it a dog off the bottom.
That or different gearing.
Or....a different cam. Hmm. Depends on your mechanical aptitude.
Is a stall converter and different gearing over kill?
Old Jul 22, 2015 | 10:20 PM
REELAV8R's Avatar
REELAV8R
I don't think so. Kinda depends on the gearing you are considering. 411 and 3500 stall might be overkill. A 355 and a 2700 ish stall wouldn't.
Old Jul 22, 2015 | 10:24 PM
1BADD78's Avatar
1BADD78
Cruising
Is a stall converter and different gear over kill?
Old Jul 22, 2015 | 10:25 PM
1BADD78's Avatar
1BADD78
Cruising
Sorry for the repeat. I was considering a 373 gear and I don't have a clue about the stall converter. Looking for suggestions.
Old Jul 23, 2015 | 02:00 AM
BOOT77's Avatar
BOOT77
Sorry still a newbe. short tube and 2" exhaust pipe.
Longtubes will get you some low end and SOP. 2-1/4 would work fine with shorties and I'd go 2-1/2 with longtubes. http://www.exhaustvideos.com/faq/how...pipe-diameter/
What kind of intake? Dual plane would get you some low end or at least adding a 4 hole spacer will help.
Plenty of ways to achieve the same results, heck you could even go to a smaller tire. What size do you have?
Old Jul 23, 2015 | 08:14 AM
augiedoggy's Avatar
augiedoggy
the downside of 3.55 gears is your rpms are going to be even higher at any given speed... it may kind of feel like the car is stuck in second gear when driving around...
Old Jul 23, 2015 | 11:28 AM
REELAV8R's Avatar
REELAV8R
Things to consider using a stall converter is the increased heat of using one. I have a 2600 stall and use an additional transmission cooler mounted up front to provide additional cooling for the transmission. Heat is the killer of the trans.
Torque converter manufacturers can give you a decent recommendation for the stall you might need based on your specs and the kind of driving you do. If I were to guess I would say around 2800 RPM with that 3.08. Maybe 2500 with a 3.55.
As augie pointed out your RPMs at cruise will rise with the use of a lower ratio gear in the back and the TH350. This calculator can help in guessing how much.
http://www.crawlpedia.com/rpm_gear_calculator.htm
If I put in my specs with 27 inch tires it tells me 2500 RPM at 65 MPH. I know from my own observation that it is more like 2700 RPM. So an auto has slippage via that torque converter.
Good torque converters will not have much slippage 2-3% at stall. Cheaper ones have more slippage and may be less durable. I would hesitate to get the cheap ones offered by on line dealers that do not build those converters. A fragged converter takes the transmission with it.
Keep in mind that an advertised stall of 2500 may vary depending on the torque developed by your engine at that RPM. My torque converter was advertised as a 2200 stall. After rebuilding the engine it stalls at 2600 due to the increased torque to the converter. This is where places that can build your toque converter can help out a lot. Some even offer to adjust your stall for free if it's not what they said it would be.
Old Jul 23, 2015 | 10:44 PM
1BADD78's Avatar
1BADD78
Cruising
Does anyone have any suggestions where to purchase a 3.73 ring and pinion.
Old Jul 23, 2015 | 10:56 PM
RIKKI Z-06's Avatar
RIKKI Z-06
Originally Posted by BKbroiler
A 383, 3,000 stall converter, 3.73 gears, that's works for me.
Nice!
Old Jul 24, 2015 | 04:10 PM
bluedawg's Avatar
bluedawg
Corvettes hook pretty fair with the independent rear, but you should still be able to spin the tires. If the stall doesn't match up to the power range it won't want to spin. Remember spinning isn't winning though.
