Mount for LS gas pedal
Old Jul 21, 2015 | 08:00 PM
vstol's Avatar
vstol
Default Mount for LS gas pedal
I have the LS-3 GM gas pedal to mount in my71 and I am looking for some ideas. Thanks
Old Jul 21, 2015 | 08:39 PM
myoriginal77's Avatar
myoriginal77
Hello,
I used the entire LS1 ( from a 2004 ) pedal assembly on my 1977, I made a template out of cardboard and fabricated an adapter that I bolted to the firewall and then bolted the LS pedal to that.
Also, I found that the original pedal ( the plastic that you push on ) from my 1977 pedal assembly fit perfectly on the LS assembly spring and all.
So I'm flooring it with the original pedal I was flooring it with -
Hope that helps,
Frank
Old Jul 22, 2015 | 06:42 AM
vstol's Avatar
vstol
thanks any pictures
Old Jul 22, 2015 | 07:22 AM
Gordonm's Avatar
Gordonm
I fabbed up an aluminum mount. Used the stock holes in the firewall
Old Jul 22, 2015 | 11:07 AM
vstol's Avatar
vstol
I saw that on you build but your pedal is different than the one I have. With the firewall the way it is the angle is wrong and I will need to kick the bottom out.
To Mount for LS gas pedal
