72 Hood release handle won't come out
Old Jul 23, 2015 | 11:45 AM
BarryB72's Avatar
BarryB72
Default 72 Hood release handle won't come out
I want to replace the hood release handle without removing the bracket. After I remove the nut/stop at the end of the wire and pull on the handle, it only comes back about 2 inches and stops. Do I just need to use some muscle? Don't want to break something and I don't want to buy a new handle until I know I can get the old one out safely.
Old Jul 23, 2015 | 12:19 PM
Mooser's Avatar
Mooser
Give it a tug
The cable has no other stop on it except that fitting at the end. Chances are (if it's anything like mine was) the cable is bent/deformed where the fitting was clamped on and that is getting caught on the entrance to the cable sleeve.
M
Old Jul 23, 2015 | 07:03 PM
BarryB72's Avatar
BarryB72
Thank you sir.
Old Jul 26, 2015 | 04:28 PM
centralcalvette's Avatar
centralcalvette
While we're on the subject, where does the bracket bolt to? Mine was Bubba'ed with a universal choke cable, I can't seem to find where the bracket bolts to.
Old Jul 26, 2015 | 05:13 PM
BarryB72's Avatar
BarryB72
above the kick panel. I can't get a wrench on the because the back side of the vent is in the way so feel around up there
Old Jul 26, 2015 | 09:38 PM
Mooser's Avatar
Mooser
PIA to get at but possible if you use the blind approach
There are two bolts, quite close together, I stuck them into the holes here to give an idea of here they are behind that vent tube
HIH
M
To 72 Hood release handle won't come out
